Carpc in 99 gs300 help
I just purchased a 99 gs300. Car is bone stock and was wondering if there was a double din type opening for this vehicle so I can install my carpc from my old car. At the moment it has the stock lexus oem radio. I need a double din type oem radio bracket. Did any of the 2nd gen lexus gs models come with a double din opening? Also how do you know if you have the Nakamichi system in the car. I was tryin to look for speakers on crutchfield.com but don't know what is the difference in radio's. Thanks for the information in advance
Is this what you are trying to do?:
More pics here:
http://forums.fluxmedia.net/showthread.php?t=899
More pics here:
Just order a double DIN dash kit off Ebay. Or you can get the OEM double din from Carson Toyota. Here are some pix of my setup. My laptop is actually under the passenger seat. The stuff in the dash is just the GPS, Audigy external sound card, automated DC-DC power supply, and other misc wiring.
More pics here:
More pics here:
I use a lilliput 629. An ebay special
What I did was to cut off the complete bottom part of the monitor housing (the button area) about 5mm below the opening for the LCD screen. This lined up perfectly when I put it behind the adaptor's with the trim-ring fitted. If you look carefully you can see ~5mm of the original liliput housing, then ~5mm of the trim ring in the shape of an upsidedown 'U', then the main adaptor.
I was in a bit of a hurry to put this together so there is no filler/sanding etc. but I am very satisfied with the result.
To control the brightness etc, I extended the IR sensor to the bottom right of the housing (tiny hole) for the IR remote, and I added a small button to control the reverse camera AV input.
I got my double din kit here:
http://www.autotoys.com/x/product.php?productid=4803
sorry no pics on how it was made. it was done by my head installer at Circuit City location where i work. he just moved the ac down. then mounted the radio with the factory brackets the mounted the screen above it and made the trim out of abs plastic. it took him about 5 hours
mista714
04-25-16 01:37 AM
