Offset Question on non-mod fenders: +30MM Front +20MM Rear on OEM 18" 245/40/18
Hello,
I am creating a new thread with updated questions to my spacer issue.
I am using 3GS OEM 18" wheels +45MM offset w/ 245/40/18 tires.
With spacers, my new offset should be:
Front will be 18x8 +30MM w/ (45MM wheel minus 15MM spacer) 245/40/18 tire
Rear will be 18x8 +20MM w/ (45MM wheel minus 25MM spacer) 245/40/18 tire
I do not want to do fender mods but i fear problems with rubbing. I am lowered on tein stech springs.
Thank you agaiN!
Thank you agaiN!
I just bought the spacers. I decided not to use 25MM spacer for the rear, so i am going with 20 instead.
This will be my setup once installed:
Rear will be 18x8 +25MM w/ (45MM wheel minus 20MM spacer) 245/40/18 tire
Sorry, I deleted my post because after re-reading what you were asking I did not think my response was what you were looking for.
Yes, with the spacer in the rear I am at +20 now. I had originally bought and tried a 20mm spacer which put it at +10 and I just did not like the look at all, plus it rubbed pretty bad. At +20 I am totally satisfied and with yours at +25 I think you'll feel the same.
15MM Front and 20MM rear for 3GS wheels 245/40/18 tires
SO,
I received my ichiba spacers today. 15MM front and 20MM rear. Looks like a good conservative setup for my 3GS wheels.
This is the setup i installed:
Front is 18x8 +30MM w/ (45MM wheel minus 15MM spacer) 245/40/18 tire
Rear is 18x8 +25MM w/ (45MM wheel minus 20MM spacer) 245/40/18 tire
Clearance is good for the tires. 25MM in the rear might have posed a problem for the 3GS 18x8 wheel in terms of rubbing. Glad i went with 20MM in the rear.
No before pictures, but i will surely add after pictures once i find time to wash my car and usable daylight for the pictures.
Should be an easy fit.
For comparison's sake, the front fitment with a 15mm spacer:
18x8.0 +30 sits on fender the same as
18x8.5 +36
18x9.0 +42
Rear fitment with 20mm spacer:
18x8.0 +25 sits same on fender as
18x8.5 +31
18x9.0 +36
18x9.5 +42
18x10 +48
Really conservative still, especially on the rear.
The only variable will be the tire choice, an how that particular
245/40-18 fits on an 18x8. It will be a little wider than the wheel,
the sidewalls would be more flush on an 18x8.5 rim lip.
18x8.5 +36
18x9.0 +42
18x8.5 +31
18x9.0 +36
18x9.5 +42
18x10 +48
Going with a +25 in the rear should be fine?
I worry that the Nitto NT555 will rub in the front. These seem to be larger than other 245/40/18's on the market.
istundra: Which tire brand are you using? Are you lowered?
Nice car. I love the saddle interior.
Side profile pictures against the fender would nice for reference. It looks like you do have some more room in the rear for a +25mm spacer.
Any issues with rubbing against the fender when you turn the steering wheel at full lock?
I worry 25MM would be bringing it close when i have a full load... or possibly lowering the car more in the future. If you can confirm it, i will definitely consider pushing 25MM.
Anyway, i am satisfied.
