high mount stop light bulb size
Old 04-27-09, 09:02 PM
gsCrazy
gsCrazy's Avatar
Default high mount stop light bulb size
hey guys,
does anyone know where i can get the 921 bulb in 5 watts? my high mount stop light bulbs went out (2 of them) and i replaced them with 194 seeing how they look the same but i still get the bulb out warning. so, i went to look for the 921 bulbs on line but it seems they only come in 17 watts or higher. our lexus manual states that we need the 5 watt 921 bulb.
also, the 921 bulb seems to be wayyyy too big to fit into the high mount stop light. i've also searched and it seems that someone found that the high mount stop light uses the 2825 bulb as per post 1.
https://www.clublexus.com/forums/gs-...-led-help.html
i have a 1999 gs300 by they way. can someone help me figure out which bulbs i need so that the annoying "bulb out" warning light turns off!
Old 04-28-09, 02:22 PM
gsCrazy
gsCrazy's Avatar
No one has had to change their high mount stop light bulbs before? Any help would be appreciated.
Old 04-28-09, 02:43 PM
AsGs300
AsGs300's Avatar
https://www.clublexus.com/forums/lig...-pictures.html
Hope this helps, its a thread on changing all your lights including the High mount Brake lights, however they are the LED ones, Might as well upgrade, good luck,
Old 04-28-09, 02:46 PM
99GSThree
99GSThree's Avatar
What bulb did you pull out of the car that was burned out??? Seems to me you would just replace it with the same number bulb,no? Try the dealer for the bulb. Or a local auto parts store. If a 921 came out of the lens,i am sure it's not waaaaayyyy too big then. Sylvania.com says the high mount bulb is a 921. The bulb should also have the number printed on the glass,very small,but should be there.
Old 04-28-09, 03:36 PM
Sydwayz
Sydwayz's Avatar
It takes 10 minutes to remove the warning light on the dash. There is a DIY thread on here for such.
Pull out the warning light and put whatever you want on the back half of the car.
Old 04-28-09, 04:31 PM
gsCrazy
gsCrazy's Avatar
i pulled out what looked like a 194 however, it had T5 printed on it. i replaced all of the bulbs with 194s but the bulb out warning light is still on. all the new bulbs light up.
so, seeing how i have no other stop lights out, i must've used a wrong bulb for the high mount. the original bulbs look like 194s but maybe they are of higher watts??? the 921 bulbs definitely do not fit in the high mount stop light housing.
Old 04-28-09, 04:32 PM
gsCrazy
gsCrazy's Avatar
i want to keep the functionality of the "bulb out" warning light.
Old 04-28-09, 05:03 PM
ntran18
ntran18's Avatar
Check the tail lights. The warning light goes on any time any of the brake lights go out. Or the bulb can be loose in its socket.
Old 04-30-09, 09:08 AM
AsGs300
AsGs300's Avatar
remove your battery terminal for about 5 min, hopefully that should reset your comp, just a thought , might ? or might not work, good luck!
Old 04-30-09, 07:53 PM
gsCrazy
gsCrazy's Avatar
alright it's finally fixed. i put in 168 bulbs in there instead of the 194s. i guess the wattage of the 194s was not high enough. the 4.9 watt 168s fixed it. the lexus owners manual states the bulb size is 921 for some reason.
thanks everyone!
i'm just going to leave a few key words below for ease of future searches.
2gs high mount stop light bulb replacement
2gs high mount stop light bulb size = 168
Old 07-21-09, 03:57 AM
Searles945
Searles945's Avatar
Thanks, this helps me out alot, that indication has been driving me insane....
Old 11-04-09, 09:34 PM
5t341th
5t341th's Avatar
hey, how do u get to the high mount anyway?
i cant seem to find a way to get to the bulbs.
do i go from the back seat?
Old 11-05-09, 03:43 PM
burny
burny's Avatar
good question. I'm guessing you have to lay in the trunk and do it somehow.
Old 11-05-09, 06:02 PM
5t341th
5t341th's Avatar
i looked in the trunk and i dont see a way of reaching the highmount
Old 11-06-09, 06:57 AM
SorrGwa
SorrGwa's Avatar
you mean the 3rd brake light thats located at the bottom of the rear windshield?
you access it from the rear deck lid, basically slide the whole unit to one side and it should be able to be poped upward and out. then unplug the single plug there.
Quick Reply: high mount stop light bulb size
