Reinstalling Spoilers What Adhesive is Good?
Old 06-14-09, 11:40 PM
VNN326
VNN326's Avatar
Default Reinstalling Spoilers What Adhesive is Good?
im trying to reinstall a spoiler on my car, i used a bunch of double sided tape none seems to hold well. what adhesive/tape do you guys use install trunk spoilers roof etc. im looking for 1 strong tape that might take someone awhile remove it .
Old 06-15-09, 12:37 AM
4play4dr
4play4dr's Avatar
if a thief wants it..its gonna be taken no matter what..but i would say that 3M heavy duty double sided tape is best..the gray one with the red cover..what spoiler are u putting on?
Old 06-15-09, 01:30 AM
Infamous 1
Infamous 1's Avatar
What he said!
Old 06-15-09, 03:00 AM
lo_dit
lo_dit's Avatar
probably the stickiest/strongest one out there. pick it up at walmart, mine was like $3.68 for a roll i believe?
Old 06-15-09, 03:33 AM
[ant]
[ant]'s Avatar
on my old S13 i bought this stuff from the local auto shop, it was sort of an equivalent to the Sikaflex but it was a different brand and meant for sealing truck trailers and all kinds of stuff. But actual Sikaflex would work too, just clean it up, run a bead, stick it on. **** is strong i dont reckon it would pull off as easily as 3M tape, but it also has some flexibility.
as for roof wing, if sticking to glass i got my glass guy to install when he put my windows back in after paint on my last car. i am not sure whether he just used some sort of sikaflex again or whether it was a glass glue type stuff...
Old 06-15-09, 07:11 AM
AristoPra
AristoPra's Avatar
so true! ! ! +1 since that's what i used on mine as well. . .
Old 06-15-09, 10:50 AM
habeeb89
habeeb89's Avatar
3M comes to mind like others have mentioned.
Old 06-15-09, 07:32 PM
VNN326
VNN326's Avatar
i dont know which one, i think it mounts on my rear winshield
Old 06-15-09, 07:35 PM
istundra
istundra's Avatar
i have used 3M on my roof spoilers and have worked well. I think because i completely lined the underside with tape and used adhesive promotor to prep the surface.
Old 06-15-09, 08:04 PM
4play4dr
4play4dr's Avatar
jus use alcohol to wipe the surface and put the tape on..my roof spoiler is being held on by that tape and it seems pretty damn hard to take off
Old 06-15-09, 09:09 PM
istundra
istundra's Avatar
Yes, rubbing alcohol should work too... but i normally use car products if the application is for cars...
Prep is the key!
6t6
03-30-15 03:56 AM
clos430
05-27-13 01:46 AM
bigfazolie
12-13-12 01:20 PM
allst4r
01-02-10 09:18 PM
Supreme86
SC- 1st Gen (1992-2000)
27
10-14-08 11:31 AM
Quick Reply: Reinstalling Spoilers What Adhesive is Good?
