H & R springs and 20x10 in the rear...
Old 06-18-09, 12:46 PM
SptDsgnGS
SptDsgnGS's Avatar
Default H & R springs and 20x10 in the rear...
will it rub...?
Old 06-18-09, 01:07 PM
Debonair
iModerate
Debonair's Avatar
Offset?
1234567890
Old 06-18-09, 01:25 PM
GS300ToM
GS300ToM's Avatar
Old 06-18-09, 01:38 PM
SptDsgnGS
SptDsgnGS's Avatar
Originally Posted by Debonair
Offset?
1234567890
im new man not quite sure...i just got them yesterday they are lexani lss-5 and the fronts are 20x8.5 and the rears are a deep dish 20x10 tires are 255\30\20 in the front and 275\30\20 in the rear...
Old 06-18-09, 01:42 PM
SptDsgnGS
SptDsgnGS's Avatar
Originally Posted by GS300ToM
im new at all this bro...sorry if i sound like an idiot and im not up to par. but i just want wheels and to lower it with no rubbing. sorry for the stupidity...
Old 06-18-09, 01:46 PM
5t341th
5t341th's Avatar
look at the back of the wheel. should be ET40 or w/e.
or just look for a number around the wheel. should be double digits
Old 06-18-09, 02:03 PM
GS300ToM
GS300ToM's Avatar
dang 255 in the fronts.... i rubbed with 20s with 245 from my fender liner with the wheels fullys turned out, i recommend u to change that down to like 245/35/20 to comspensate for the rear 275/30 or your speedo will be off.. i now have 19x8.5 with 225/35 in front and 19x9.5 with 245/35 rear no rubbing but rears are rolled tho, hope this helps
here's a link to read up on tire setup
https://www.clublexus.com/forums/gs-...-05-sc430.html
shock/springs/coils/tire combos......
https://www.clublexus.com/forums/gs-s...d-threads.html
Old 06-18-09, 02:27 PM
SptDsgnGS
SptDsgnGS's Avatar
the digits are 97y
Old 06-18-09, 02:39 PM
Debonair
iModerate
Debonair's Avatar
Where did you get them from? The shop or person that sold them to you should be able to tell you the offset for each wheel.
Example:
Old 06-18-09, 02:47 PM
GS300ToM
GS300ToM's Avatar
Originally Posted by SptDsgnGS
the digits are 97y
lol look at it again
Old 06-18-09, 03:08 PM
RMMGS4
Northern California Regional Officer
RMMGS4's Avatar
If you have the right offset or slightly mod the inner fender lip, the rear will not rub at all.
Now the fronts, I have the same size tire on 20x9. If you drop very low or have soft springs you will rub the inner fender well, unless you extensively mod the inner liner and fender lip. I wouldn't run this size without checking out all these issues.
Again we need offsets for front and rear or you WILL NOT get a clear answer from anyone.
Old 06-18-09, 03:11 PM
SptDsgnGS
SptDsgnGS's Avatar
ok i will get it thanks guys...
Old 06-19-09, 08:59 AM
SptDsgnGS
SptDsgnGS's Avatar
ok the front offsets are 35MM and the rears are 38mm
defo
08-13-13 10:15 PM
mdgrwl
04-14-09 09:41 AM
charmz
Suspension and Brakes
04-04-08 08:43 AM
safricags
03-11-08 05:22 AM
ted920
Wheels, Tires & Brakes Forum
01-25-03 12:44 AM
Quick Reply: H & R springs and 20x10 in the rear...
