tanabe medallion installed - few q's in sound
I know most the fellow members here would disagree but here goes.
So I got my tanabe medallion installed 2 days ago. I love the way it looks and sounds on highway speeds but the low end revving & the loss in back pressure makes the vehicle VERY sluggish for the i6 and is too much for me and my wife (wish i had the 430 here). I do NOT want to change it back to stock i just want to tone down that low end RAAAENG sound and make it a hum. I am near 30yrs old and just want the vehicle mainly for appearance/functionality factors. what choices do I have to tone down the exhaust just about 1/2 to 1/4 more? adding aftermarket resonators and deleting the straight pipes off the cat back? or can i keep the original construction of the tanabe in case i sell the vehicle down the line and add a resonator somewhere else along the piping to lower the sound and gain back a little of the back pressure?
PLEASE SEE BELOW POST #15 - NEED HELP WITH PIPING DIAMETER
which did you get? the Hyper or Touring? i think the hyper is no longer available. It sucks that you spend all that money and time to have something you were apparently not prepared for.
Either way depending the model you can put on silencers at the tips, the Hyper uses the same size tip dim. apexi uses for there silencers.
are you getting drone in lower gears?
yah. it seems most folks who has the right sound in all came from the 400/430's but the 300's are not quite there. maybe i need to drive another few hundred miles break them in fully. i already put a good 150 + miles on it driving spirited with stop and go.
http://cgi.ebay.com/ebaymotors/APEXI...Q5fAccessories
Not really unless your Boosted. it is recommended not to boost when its closed since there will be too much back pressure causing a drop in boost level.
On an NA, totally different story. BTW when the valve is closed there is still a min amount of open area, otherwise you would stall
another option is to get an apexi EVC. i have one on my supra and had one on my Silvia back in the day. It is a nice piece and works well. works so well it reduced my cabin and most important outside noise by half. I used it when rolling by the PIGS. they never bothered me once. i would look into other options beside cutting and modifying the Tanabe or OEM Pre cat-back. Once you customize it its hard to go back to OEM specs, and can be a pain when trying to sell either the car or exhaust.
anyone know which one would fit our 2nd gens?
155-A020 ECV, Flange-Type 51mm 90-107mm
155-A022 ECV, FLANGE-TYPE. 61mm 92-110mm
http://www.apexi-usa.com/products/?id=5326&rsku=0
shouldnt i use a 61mm? since the piping diameter for the Tanabe medallion is 60mm? im afraid the 67mm seems too big but I could be wrong?
