Wheel width/offset/size and tire fitment Q&A thread
Old 03-26-12, 05:07 PM
  #256
JDMsedan
JDMsedan's Avatar
I wonder what tire size he used?
Old 03-26-12, 05:25 PM
  #257
JDMsedan
JDMsedan's Avatar
Originally Posted by JDMsedan
I'm looking to get some 18x9.5 +30 front and 18x10.5 rear. I have searched high and low and I can't get a straight answer as to wether or not these will fit my 2GS.
If anybody knows, what type of fender work will need to be done?
I kind of have some tire sizes in mind.
I was thinking 225 40 18 front and 255 40 18 rear. Any thoughts?
So nobody huh?
I was going to run these in the Varrstoen 1.1.1.
Old 03-26-12, 07:23 PM
  #258
Anthony
Anthony's Avatar
front should be good with that size and a roll. as for the rear.. what offset? if its a +30 id probably knock down that size to a 235/40 and a shave
Old 03-27-12, 09:33 AM
  #259
Vishuz
Vishuz's Avatar
Im planning on getting 20x8.5 upfront and 20x10.5 in the rear and im currently dropped on tanabe DF210 Srpings.....what size tires should i get so it wont rub my fenders? Also should i take out my fender liners
Old 03-29-12, 09:33 PM
  #260
step2me
step2me's Avatar
Default will these fit
SIZE and SPECIFICATION: The wheels are size 20x8.5 ET20 (Front) and 20x10 ET25 (Rear), Black finish with Chrome lip , 5x114.3 bolt pattern. all my suspention is stock will these fit even though the offset is wrong?????????????
Old 04-06-12, 11:43 AM
  #261
Intellexual
Intellexual's Avatar
I'm looking at the Enkei NT03+M wheels in the 18x9.5 size front and rear (square set up). The wheels come in both +27 and +40 offsets, and I'd like both front and rear to have the same wheels and tires.
My car is at stock ride height right now and at most will be lowered 1"-1.5".
I'm looking to do minimal fender work.
My tire of preference is 245/40/18 front and rear.
1) What will be required to fit the 18x9.5 +27 with 245/40/18 tire front/rear?
2) Will the 18x9.5 +40 with 245/40/18 tire fit the front/rear without hitting the control arms?
3) Would you recommend the +27 or +40 from an ease of fitment perspective?
Thank you.
Old 04-11-12, 01:00 AM
  #262
VINCE9164
VINCE9164's Avatar
19x8.5 +50 19/45/235
19x9.5 +45 19/40/255
Will these fit flush @ stock height?
Old 04-11-12, 03:11 AM
  #263
LexiGS4ty
LexiGS4ty's Avatar
Alright got these 20's that came with the car wheel specs:
F - 20x8.5 255/30/20 Offsets: +30 Nexen N3000
R - 20x8.5 255/30/20 Offsets: +30 Nexen N3000
Im planning on dropping it with H&R Springs
Lowers the Front - 1.4" and Rear - 1.3"
Will it rub?
Old 04-11-12, 04:01 AM
  #264
jriggs
jriggs's Avatar
they well not be flush.
19x8.5 et35 is pretty flush in the front
19x9.5 et 38 flushes nicely the rear
Old 04-11-12, 04:05 AM
  #265
jriggs
jriggs's Avatar
Thank you.
1) camber + pulled fenders
2) will fit fine
3) not so much
Old 04-11-12, 04:08 AM
  #266
jriggs
jriggs's Avatar
Will it rub?
Assuming no camber or body work. Fronts will probably rub. Rears will probably be fine
Old 04-11-12, 04:10 AM
  #267
LexiGS4ty
LexiGS4ty's Avatar
Alright, so would simple heating and molding will do? or fender shave / roll etcetc?
Had new oem struts replaced recently would it give it some negative camber at all?
Old 04-12-12, 06:19 PM
  #268
VINCE9164
VINCE9164's Avatar
Thoughts of running a squared setup 19x10 all around 3" lip?
Thinking about buying a set but wouldn't it look weird having the same size lip all around?
Old 04-12-12, 06:26 PM
  #269
SSxblazer
SSxblazer's Avatar
About to do a test fit, but wanted feedback from others....
Nismo 350z wheels.....on a Gs300 (03).
Front
Offset: +30mm
Weight: 21 lbs 4 oz
Tire: Bridgestone RE050A 245/40/18
Rear
Offset: +30mm
Weight: 29 lbs 8 oz
Tire: Bridgestone RE050A 265/35/19
Just curious if stock height will work? I will worry about lowering later.....
Old 04-12-12, 06:37 PM
  #270
jcat_350
jcat_350's Avatar
yes, same lip all around would look weird. You'd typically want your deeper lip in the rear as most 'sportier' staggered setups use a lower offset in the front to clear BBK's.
Front
Offset: +30mm
Weight: 21 lbs 4 oz
Rear
Offset: +30mm
Weight: 29 lbs 8 oz
stock height I don't see that being a problem. However, why run an 18 up front and a 19 out back? Won't screw anything up but it looks weird and throws off your suspension geometry depending what you do with ride height front to rear.
Tirewise I don't see any issues, the 10" rim is a bit wide but with a 30mm offset that pushes it out 15-20mm further than the stock rim, should be enough to clear. Just be wary of those bridgestone RE050 if you're trying to get a stretch on the sidewall at all, they're notoriously stiff tires.
QLex300 (09-15-22)
Quick Reply: Wheel width/offset/size and tire fitment Q&A thread
