Finally solved, 98 99 side view mirror spring installation problem!!!
As others, I have been wrestling with trying to find a way to compress the spring in the side view mirror for re-installation. Zip ties are to thick, there is very little clearance for anything. After around 6 haurs last night wondering how Toyota achieved assembly, I came to the conclusion they used a special tool, so I cut 2 ring off the passenger side spring and reinstalled, BUT WAIT, THATS NOT THE SOLUTION! So the next day I was on to the drivers side with a new idea that actually worked, 80lb fishing test line!
I first wrapped 3 sides of the spring, which barely fit, I then only wrapped two even sides (be careful they are even or one will slide to the other side) and it fit perfect. Install the spring, place the clip over the top, and used a model car exacto blade to cut the line!
i posted in my DIY all the differences i saw....i guess this clip is in the base which i didnt take apart so i never noticed it
nicks88
05-20-12 11:05 AM
Luc
10-21-02 03:44 PM
