No acceleration !
No acceleration !
Today I changed.my front shocks and the TPS Sensor.
Shocks were no biggy neither was the tps until I went to start the car and it turned over fine but when I gave it gas nothing happened the cable moves on the throttle body but engine doesn't respond . Car moves once the pedal is completely up against the floor ! Any input is appreciated as this is the only household car thanks
I would hold off on the throttle control motor until you are sure you have the tps installed correctly. If you have a decent obdii scanner it will tell you if the tps is installed correctly. If I remember correctly, at idle the tps should read 14-16%. The online manual details how to install it properly.
when you say scan tool u mean the one that autozone will plug in to diagnose a check engine ?
and CLOS430 i replaced it because it would go into limp mode and after shutting the car off and back on it would drive normally so i changed that being it was 60$
http://www.autozone.com/autozone/acc...ier=98817_0_0_
The accelerator position sensor could be bad also. If you want to check the throttle control motor, check the online manual here.
http://bahamutcars.free.fr/workshop/...nts/index.html
You canuse a multi-meter to test the resistance of the motor to see if it's in spec.
got to the ECM checked all connections everything seemed snug and tight no corrosion and i did the ohm test on the harness itself GOT nothing and i did the ohm test on ECM and numbers came back good
after putting the ohm tester to each sensor only one that came back with 0.0 was the throttle control motor !
Just make sure you are checking the tcm at the plug under the hood. When I changed mines it wasn't zero but it was out of spec. I don't think zero ohms is correct. That would mean a complete short. You have to check certain pinouts in the tcm connector. Did you check it the way the manual tells you to?
