Widest Rear Tire you can fit behind a GS400/430
Old 12-07-11, 10:43 PM
BayAreaLex
BayAreaLex's Avatar
Default Widest Rear Tire you can fit behind a GS400/430
Hi folks, what's the widest tire you can fit behind a GS400/GS430 with no modifications?
Can I stuff a 19x10 back there? What offset is recommended and tire size?
Drop will be 30mm if it matters
Thanks
Old 12-07-11, 10:45 PM
marus
marus's Avatar
you can definitely fit that back there......... im about to stick an 12 with 6 offset back there hope either next week or he week after
Old 12-08-11, 11:46 AM
epic1si
epic1si's Avatar
i run a 19x10 with 295/30/19's can't remember the offset it's in the high 20's though maybe even 30
Old 12-08-11, 12:29 PM
BayAreaLex
BayAreaLex's Avatar
Do you have a picture available?
I'm hoping to get a good understanding of what offsets work well. Also, are the fender lips on these cars rolled from the factory?
Old 12-08-11, 12:34 PM
1sikgs
1sikgs's Avatar
i'm running a 285/30r20 on a 20x10.5 with a +30 offset. so i'm sure you can fit a 295 tire if you're gonna run 19s
Old 12-08-11, 12:44 PM
BayAreaLex
BayAreaLex's Avatar
Hey folks, I've done a search on pics available and often people aren't stating the wheel size/offset and tire size.
It would be helpful to see some pics with the size noted
Old 12-08-11, 01:41 PM
veritek
veritek's Avatar
Well, you can definitely fit a 10" wide tire on the rear, and even wider, as long as you run a conservative offset on the wheel, so it all depends on the wheel offset. You should be alright with +38 or higher for sure. Regarding the fenders, Lexus doesn't roll their fenders, nor do any manufacturers for the most part, if at all. You need to get a fender rolling machine or be really good with a baseball bat placed between the tire and the fender.
Old 12-08-11, 02:40 PM
AMA0627
AMA0627's Avatar
Im running a +38 9.5 inch on the rear with some fat 295/40/18's, ( i got a killer deal on them so i had to buy them).. I was told on this site that they wouldnt fit, but they have a bout a centimeter between the fender (rolled) and the tire..slammed all the way down on Tein CM's. Once i burn through these, i'll put a 30 series tire on it for a better look, but they do fit. I hope they hook
Old 12-08-11, 02:43 PM
Bippu147
Bippu147's Avatar
I can run a 315 on stock body
Old 12-08-11, 10:34 PM
SoCalSC4
SoCalSC4's Avatar
LOL... where is the *yawning* emoticon?
No mods? What's the fun in that?!
Old 12-08-11, 11:07 PM
Bippu147
Bippu147's Avatar
lol. i'm running a 325 with pulled and flared fenders
Old 12-09-11, 06:23 AM
Teasy010
Teasy010's Avatar
Hey guys... I'm planning to get 19's but I don't want staggered rims. How low can I lower my car without causing rub or other issues? I'd appreciate any help. Thank you
Old 12-09-11, 06:31 AM
Teasy010
Teasy010's Avatar
I really like the look of the stock mesh wheels of the BMW. Bbs I think?! Does Nyone know if those rims will fit on a 99 gs400?
Old 12-09-11, 07:43 AM
850Lexus
850Lexus's Avatar
I do believe that BMW wheels are 5x120
Old 12-09-11, 08:09 AM
gs300yerg
gs300yerg's Avatar
im looking at getting an 18x10.5 with a +20 offset and was actually curious on if all i would need to do is a fender roll if i were to put a light stretch on it
Quick Reply: Widest Rear Tire you can fit behind a GS400/430
