electrical issues
Old 01-04-12, 05:58 PM
sam12345
sam12345's Avatar
Default electrical issues
I have the following things not working
On instrument panel:
temperature gauge always is on cold
Leds that show shifter position do not light up (none of them)
Memory:
Memory buttons do not work nor do they beep when you set them
Power tilt and telescope exit feature:
Sometimes it works sometimes it does not (most of the time it does not work on entry but it does on exit and sometimes it works in reverse)
Intermittent door open light on dash when doors are closed
Intermittent dome light stays on when door closed (does not correlate with dash door open light)
some times the headlights do not go off after 30 sec delay (when all doors are locked)
Blower motor does not work (If I disconnect the white connector next to the blue relay on passenger side all the blower motor speeds work for a while then it seems the black relay click it off already changed the relay)
Side mirrors can not adjust with side mirror adjustment button (neither side)
I cleaned with contact spray all the connector on the drivers side fuse the passengers side fuse and the ones in the drivers side door (still have not done passenger side door)
I disconnected body control module number one (passenger side ) and cleaned and reconnected
My low fuel light blinks even when tank is full
My question:
Is this the Body control module issue or is it one of the modules in the doors or multiple modules or something else?
Car runs perfect
Old 01-04-12, 09:05 PM
sam12345
sam12345's Avatar
Does any body know what each body control module control?
What does the body control module behind the left (drivers side) fuse box control?
What does the body control module behind the right side (passenger side) fuse box control?
What does the module in the left (drivers side) door control?
what does the module on the right (passenger side) door control?
Old 01-04-12, 10:08 PM
battery188
battery188's Avatar
wow, I couldn't remember all those problems and write them on one post. what a headache!
first things first. you did check all of the fuses right?
It sounds like a loose wire somewhere touching the ground. I suspect somewhere on your driver side
Old 01-04-12, 11:15 PM
sam12345
sam12345's Avatar
no I cleaned every connector and checked every fuse and wire all as it should be. From reading posts its one of the body control modules. I need to know which one does what so I change the correct one. I think its the passenger side one but I am not sure. Someone with a shop manual should be able to tell me.
Old 01-05-12, 08:08 AM
sam12345
sam12345's Avatar
somebody must have the electrical schematics for this car that can help me. If not does anyone know where I can get them?
Old 01-05-12, 09:11 AM
sam12345
sam12345's Avatar
I found this service bulletin
any one familiar with it?
Heating and Air Conditioning: All Technical Service Bulletins
A/C - Solution to General Malfunctions
HEATING & AIR CONDITIONING
AC003-98
Title:
AIR CONDITIONER MALFUNCTIONS
Models:
'98 GS 300/400
September 4, 1998
Introduction
Some early production 1998 model year GS 300s and 400s may display one or more of the following conditions while driving with the Air Conditioner
ON:
^ Air Conditioner Magnetic Clutch will not engage.
^ Engine Coolant Temperature Gauge
does not function.
^ Automatic Transmission Indicator Lamp in combination meter doesn't function.
^ Outside Temperature Display indicates two centered bars illuminated (as shown in illustration) "freezes" or goes blank.
^ Blower motor inoperative
NOTE:
1. Normal A/C system operation is restored after the ignition switch is cycled once.
2. Condition may be Intermittent.
Affected Vehicles
^ 1998 model year GS 300s produced before VIN JT8BD68S*W0020000 and
1998 model year GS 400s produced before VIN JT8BH68X*WOOO74OO
Parts Information
Warranty Information
Production Change Information
Repair Procedure
1. If a 1998 model GS produced prior to the VIN indicated in the Production Change Information table exhibits any of the symptoms described,
replace the AC ECU with an improved one as indicated in the parts information table.
2. Additionally, check the part number of the ECM and replace if it is not a current production part as indicated in the parts information table.
NOTE:
ECM may have been replaced with current production part for SSC WL2. Always verity involvement/completion of SSC WL2 prior to proceeding
with ECM replacement. lithe vehicle is involved In SSC WL2, but does not show completion, follow SSC WL2 procedures for ECM replacement.
Old 01-05-12, 09:31 AM
sam12345
sam12345's Avatar
Here is another article. Which ECU?
Check Wiring
If you experience problems such as windows that do not roll down, side-view mirrors that do not move, or interior warning lights that signal an electrical problem, go to a Lexus dealership for repair service. In the event of a poorly replaced windshield, water can cause the electronic control unit (ECU) to malfunction. If this problem is ignored, all electrical components would eventually malfunction. Early diagnostic testing can save thousands of dollars on costly electrical repairs.
Read more: Lexus GS400 Service Tips | eHow.com http://www.ehow.com/list_7505224_lex...#ixzz1ibdFQO6J
Old 01-05-12, 10:20 AM
sam12345
sam12345's Avatar
I am going to change the passenger side BCM and see what happens. Any input would be appreciated
Old 01-05-12, 06:36 PM
sam12345
sam12345's Avatar
here is the service bulleting
File Type: pdf
Old 01-05-12, 09:25 PM
battery188
battery188's Avatar
http://bahamutcars.free.fr/workshop/...nts/index.html
With your symptoms check body ecu no.2
Old 01-05-12, 10:21 PM
sam12345
sam12345's Avatar
that pdf manual does not work. How do you get it to work?
Old 01-12-12, 07:11 PM
sam12345
sam12345's Avatar
well it is not either of the Body control modules. If I remove either the efi relay or efi fuse in the engine compartment fuse box then everything works except the gauge (and of course the engine does not run). Some sort of short or Engine control module mentioned above article? I checked my Engine control module part number and it did not match the one they mention but my car is within the VIN number mentioned. Any ideas anyone?
Old 01-14-12, 05:54 PM
sam12345
sam12345's Avatar
Is the body ecu and the ECM linked and can they affect each others function?
I wrote down all my issues. Replacing the drivers side body control module seems to have fixed my park lock issue (solenoid that unlocks shift lever works)
Here are the issues when the fuel injection fuse is connected.
1. AC/Htr blower does not work
2. AC controls on the navi do not work (if I plug a manual ac control the controls work but the blower motor does not)
3. mirror adjustment controls do not work (either side)
4. PRNDL lights on the instrument panel do not light up
5. Temperature gauge always on cold (all is normal on the scan gauge)
6. fuel low light flashes
7. ECT light does not work
8. Snow light does not work
9. The lcd on the intrument panel does not show what gear you are in (in manual mode)
10. Outside temp does not show on nav (nav looks dim on climate setting) all other settings seem to work normal
11. Memory seat, column ect do not work. memory buttons do not beep when trying to set position
12. Cruise control works but light does not show on dash when activated
13. Door open light works most of the time but not always
14. No power at power outlet in center box (the extra power outlet, cigarrete one works fine)
15 power telescope mode intermittent, Almost always works on exit but rarely on entrance
After I remove the EFI fuse or relay
1,2,3,13,15 all work
the rest stay the same.
Since I already changed both body control modules could this be the ECM?
Somebody please help. I still think its a multiplexing problem
Old 01-15-12, 07:35 AM
sam12345
sam12345's Avatar
Well I ordered an ecm from the classifieds. Lets hope the TSB is correct. my vin matches the tsb numbers but my ecm ends in a 3 either way its supposed to have one that ends in a 4.
Old 01-23-12, 09:08 PM
sam12345
sam12345's Avatar
Well good news! It was the ECM. Absolutely everything works. One weird thing, I seem to have lost a tiny bit of power. Before changing the ECM my zero to 60 was between 5.8 to 6.2 seconds (I'm at 3800 feet altitude) I just checked my 0 to 60 and it was 6.8 seconds. I suspect my old ECM might be modified (maybe a performance chip?) which might have been the source of the failure. Of course it could be the test conditions but the seat of the pants seems less
Power also.
Quick Reply: electrical issues
