TSX retrofit
Old 05-31-12, 09:25 AM
STR
STR's Avatar
Default TSX retrofit
I thinking of picking up some TSX projectors and was wondering if anyone has had any experience with doing this retro fit into a GS. I searched, but could not find anything about it. I know Luxur Mods has brackets for other projectors, but not the TSX. Does anyone know what would be involved with this? Thanks.
Old 05-31-12, 10:01 AM
21SF
21SF's Avatar
They are kinda small for the gs headlights, may look wierd. Stick with LS series or Q45.
To answer your question you would need to cut up your reflector and epoxy or screw the projectors to that, with the bracket you just replace the reflector with the bracket and projector.
Old 05-31-12, 10:19 AM
LuxuryGS3
LuxuryGS3's Avatar
TSX will fit in the high beams. I have TSX in my high beams in my retrofit that I will be getting in the next couple of weeks. For the low beams you're going to want LS460/M45/LS430/Q45..
Old 05-31-12, 10:22 AM
SPRTNYDSN
SPRTNYDSN's Avatar
I'm doing FX-R retrofit. Doesn't fill the large hole but it does the job. TSX are pretty small. You can try the FX-R or BI-XENON: ACURA TL / ZKW-R lens if you can 't get the Q45 or LS430 projectors.
Old 05-31-12, 10:25 AM
STR
STR's Avatar
Cool. Thanks for the input. Saved me from buying something! I'm gonna look into the LS460/430 projectors.
Old 05-31-12, 12:06 PM
tn96dc
tn96dc's Avatar
I plan on using FX-R projectors
Old 05-31-12, 12:50 PM
STR
STR's Avatar
What about the projectors from the RX. Will those work or are they too small as well?
Old 05-31-12, 01:09 PM
excluesive
excluesive's Avatar
most projectors are small for the space, you just need a nice shroud to make the void pretty
Old 05-31-12, 02:16 PM
smooth0033
smooth0033's Avatar
This is TSX projectors done by JLC in So Cal.
Old 05-31-12, 03:33 PM
VINCE9164
VINCE9164's Avatar
Sorry to thread jack, but will the SC projectors fit?
Old 05-31-12, 03:56 PM
21SF
21SF's Avatar
I dont know any projectors that WONT fit, some just perform, look better, and are easier to install.
Old 05-31-12, 03:57 PM
NEbiker10
NEbiker10's Avatar
TSX would look weird
Old 05-31-12, 08:40 PM
YxUxMADDDD
YxUxMADDDD's Avatar
I got tsx I'm about to do for the lows.
Old 05-31-12, 11:38 PM
SPRTNYDSN
SPRTNYDSN's Avatar
Here's mine with Sportdesign headlights with FX-R version 1 with luxury mod brackets and white LEDS rings.
Old 05-31-12, 11:49 PM
abounly
abounly's Avatar
Hope your thinking about the sc430.
Why would it look weird? Cause its small?
If the projectors aren't LS430/Q45 you get shrouds to cover up the empty space. I'm running FX-Rs
Quick Reply: TSX retrofit
