*DIY* SIMPLE EASY NO FUSS AUX INPUT for factory headunit
#106
There are plenty of different ways to do this. The way of taking it apart and soldering and cutting costs next to nothing. All those adapters cost a lot more. And also, those adapters are for only the big antenna part. Some cars have a dual antenna in.
#108
The reason I took apart the headunit and did it the way I did was to have it right in front of the radio, have no switches or relays, and it cost me less than 5 bucks. It doesn't matter where you interrupt the FM signal, the sound quality will be the same. The quality is better than the FM signal because your source has better quality. (iPod, phone, MP3, etc.) I didn't want to spend 30-100 dollars to have an input.
#109
It's 5 wires. Right positive in, right positive out, left positive in, left positive out, and a common ground. And yes they all go to the plug that's in the front face.
#111
Yea no forget it, honestly I already went with your method on a spare head unit I have, figured why poay more, have more of a unit when I was just a tiny little AUX hole like his, Thanks Jay! but while I have your attention! Ive soldered the wires all onto the circuit board, but I just dont clearly understand what you do with the six soldered wires? they all connect to the AUX port? I just need to go buy one of those, just a AUX input is all it is right?
you wouldnt happen to have photo's of this end would you? that would have really been nice to see dang
#113
I have had no luck with anyone sending me a unit or detailed pictures of any navi head unit. I did just pick up a 02 IS300 that I will be taking apart to figure out. Someone must have thought it was a 7 disk changer and broke everything inside by adding an extra disk. Oh and that's why I took the picture of the aux plug package with the part number.
#115
Hey awesome thread. I recently did the first part of this install and it sounded GREAT. Instead of mounting the aux in the front of the radio I just ran a wire up through the front of the tape deck. Didn't look too good, but it sounded awesome
However, today when I went to mount the aux to the front of the faceplate I now no longer have any LCD display and the volume **** doesn't work at all anymore. I get sound but I can't adjust the volume and the LCD screen is totally blank.
Any ideas what could be going wrong?
tldr: did the install, sounded great, but now LCD and volume don't work, need help!
#119
Biatchin ! ! ! !
Works GREAT...
Only issue is a lot of alternator / ignition noise if I'm charging the phone at the same time.
Other than that - awesome.
Thanks Jay - You Da Man!
Update: Static / alternator / ignition noise goes away when you take care of the ground loop as discussed in this thread.
Ground the lighter to the radio. . easy fix.
Outside of cigarette lighter is ground...lead wire to bolts holding radio.
Then again...streaming music takes like no juice from the phone.
All this for for like $4.00 of parts and an hour or two of my time..long overdue.
Again . .Thank YOU Jay!!!!
Works GREAT...
#120
We just did this to both mt gs300 and my hubby's gs400 works like a charm and we took plenty of picks I was gonna do a write up and give this guy credit for an awesome fix!
