Lexus gs300 leather seat restoration and repair need suggestions
Old 01-15-13, 01:31 PM
Iparkcars
Iparkcars's Avatar
Default Lexus gs300 leather seat restoration and repair need suggestions
I Have a 03 Lexus gs3000 the car is in very good condition low miles engines runs good and it is very clean.I brought the car from Miami the owner really didnt condition the seat good.The seats where hard and cracked on the driver side bolster lower and upper. I was wondering if Leatherique would be a good choice to use to repair the seats or should I just replace them.Im located in the Charlotte NC area if anyone knows a good shop thats not too expensive.Here are the pics of the drivers side bolster the passenger side is almost perfect
.Lexus gs300 leather seat restoration and repair need suggestions-20130115_112614_resized.jpg
Lexus gs300 leather seat restoration and repair need suggestions-20130115_112639_resized.jpg
Lexus gs300 leather seat restoration and repair need suggestions-20130115_112804_resized.jpg
Lexus gs300 leather seat restoration and repair need suggestions-20130115_112629_resized.jpg
Thanks in advance
Old 01-15-13, 01:56 PM
Acer
Acer's Avatar
Would like to know this also
Old 01-15-13, 02:25 PM
Debonair
iModerate
Debonair's Avatar
Search all of CL for Leatherique threads. Here are a couple threads to start with.
Leatherique+++Seats repaired and redyed
Leather Reconditioning *2012 UPDATE*
Old 01-15-13, 03:00 PM
Iparkcars
Iparkcars's Avatar
thanks Debonair question is do I have to wait til the summer to do this process or could I use a hair dryer as a means of heat. AlSo dors anyone know the color match for my seats for the leatherique dye?
Posted from ClubLexus.com App for Android
Old 01-15-13, 06:25 PM
sam12345
sam12345's Avatar
You send a pice of your upholstery to them that you can cut from under your back seat and they match it
Old 01-16-13, 01:33 AM
77i9
77i9's Avatar
Clazzio makes awesome seat covers
Old 01-16-13, 04:57 AM
SprtDesign
SprtDesign's Avatar
Just bite the bullet and get the two front seats recovered. None of the magic dyes will hold up to daily use. Unless the seats have tears or rips in them, and you want a cheap quick fix i would go with that.
My dr. seat has seen the miles with 14 yrs of use. My goal is to find a low mileage dr. seat and swap it in.
Old 01-16-13, 08:16 AM
Iparkcars
Iparkcars's Avatar
I dont drive the car much i have a daily driver car.I just dont like how it looks now.How much would it cost to replace the leather on the bolster upper and lower of the driver side seat or would I have to replace the whole thing?If I did go the leatherique route would I have to wait til the summer to do this?
Old 01-16-13, 08:41 PM
sam12345
sam12345's Avatar
Don't you have a garage? I would go with the die if you want cheap but you will have to redie it every so often. Reapohlstery will probably be in the 800 range clazios are about 450 for all the seats
Old 01-17-13, 05:19 AM
Iparkcars
Iparkcars's Avatar
I currently dont have a garage im in a apt looking for a house currently. I have access to a garage if I need to use one for a.couple days.I read about the clazzio seat covers and they look good but im not sure I like that they are not full leather.I see it takes a couple months to get them as well. If I do a solid color will it take that long? For the leatherique process would I have wait til the warmer months or just use a garage to do it? For anyone who used Leatherique are you happy with the results and did it hold up over time.Thanks
Old 01-17-13, 06:17 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,273 Likes on 1,380 Posts
You might also want to post a WTB in the classifieds. Some folks who recover with a leatherseats.com or other cover may have their OEM leather (in better condition than yours) just sitting in a box somewhere.
Old 01-17-13, 08:28 AM
LuxuryGS3
LuxuryGS3's Avatar
Clazzio seat covers may be your best bet. They're nice and not a back breaker when it comes to expense. Although just getting your front seats redone at a shop will probably be cheaper. It won't be $800.
Old 01-17-13, 05:33 PM
sam12345
sam12345's Avatar
The rejuvenator oil from leatherique works better in the summer but you can use the die anytime just need a garage because freezing temp won't work. My seats were like yours in one part and they have a paste to fill the cracks then you die over it. It takes some technique but it will look good for a while. From then on you will need to do maintenance every so often so it's not like new leather seats.
Old 01-18-13, 01:02 PM
Iparkcars
Iparkcars's Avatar
how long are you talking when you say last for a while? when you say matainance you mean redo the fill and dye process or are you talking keeping it up by conditioning your work?
Old 01-18-13, 05:06 PM
sam12345
sam12345's Avatar
About a year. Yes, redo die and possibly fill but not to such a great extent. Your seats are about to crack through and once that happens you need to either replace that piece or redo the entire thing. If you clean it with 50% woo lite and 50 % hot water with a brush, dry it, the condition the snot out of it (will get sticky for a while) with lexol it will look a lot better do this while you are waiting for your die. The only place you will need the paste is where the grooves are deep (most of yours are not just the left butt cheek area) when you put the die on you will be amazed how all the lines blend in. You put on very thin coats, but if you have an airbrush gun then it comes out even better. You can also find people who do this for a living and will charge about 150 for both seats.(they can also restore your steering wheel) ask a luxury car used car dealer who they use because they all use these guys to increase the value of their used cars. If your center arm rest is wasted their is a guy on eBay who sells the leather or vynil if you prefer cover for it. He will match your color. By the way, you should condition your leather twice a month to prevent this in the first place
Quick Reply: Lexus gs300 leather seat restoration and repair need suggestions
