DIY: mounting the front licence plate without visible holes
well this is actually pretty easy DIY, it works and cosmetic-wise you don't see anything
a lot of people complain that the GS doesn't have any mounting mechanism on the front bumper for the licence plate, so if you put on the plate, you end up with ugly holes on the bumper.
well that's over, i managed to put on the licence plate without any holes on the front site of the front bumper
the trick? try to put it under the bumper ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
so here it is. get two L brackets, and mount the bottom side of the licence plate to one side of the bracket.
![](https://www.clublexus.com/gallery/data/500/medium/7957resize_of_img_1063.jpg)
couple of things to look out for. the L bracket has to be large enough so it will allow the screw and bolt to tighten up the front licence plate without scratching the bumper. on the other hand, you don't want the L bracket to be too long as well otherwise it would stick out too much
same thing for the bolt that ties the licence plate to the L bracket. you want it short so it won't touch the bumper
this is a closer look. i got washer and stuff to make sure it's tight
![](https://www.clublexus.com/gallery/data/500/medium/7957resize_of_img_1064.jpg)
then the next thing you would do is just to use a drill, drill up two holes at the bottom of the bumper, and use a sharp screw to screw the L brackets to the bumper. you shouldn't hit any metal at all
it's that easy ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
![](https://www.clublexus.com/gallery/data/500/medium/7957resize_of_img_1062.jpg)
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
if I was you, I would mount a lisence plate frame infront of that plate. Keep the plate solid, your plate as is will probably flex under strong wind or high speed driving.
Originally posted by rominl
well i don't want to, but my gf was pulled for no front plate and i HAD to do something to get the ticket signed off, so i had no choice
tomtnc
02-18-03 12:18 AM
