Work Around for DVD/Nav? (Operate while car is in Motion)
#31
MultiTasking Mom
there is some interesting discussion in the GX forum about a company that is making this bypass kit for the "i agree" button as well as the motion control of nav and bluetooth. i am anxious to see if it works (will be out in 6-8 wks). it's a $75 mod that doesn't involve cutting wires or voiding warranties, which would be great.
read about it here: https://www.clublexus.com/forums/sho...d.php?t=159170
#32
You can change destination on the NAV while moving without doing all this rewiring stuff. There is an Override button in our system. I will take pictures step by step for you guys tomorrow. Only thing is, you have to do it every time you start your car as the system resets back to default. You can change destinations moving (we tried and confirmed this on my GS going 70mph). We know this procedure works on 05 LS430, so I assume on all Gen 4 Nav.
#33
#36
Originally Posted by idg
Does this also apply to the handsfree bluetooth phone (ability to dial any number while in motion)? Also, how about the DVD player?
#37
#38
Not kidding at all. I'm sure Lexus will be pissed if they see this on this forum.
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
#40
#41
Originally Posted by Ex996
What's the story, bro? Were you BSing?
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
https://www.clublexus.com/forums/sho...d.php?t=167666
#43
Originally Posted by GS4fun
if i wanted to put a switch to turn on the rear camera without being in reverse mode....any guesses which wires i would have to play around with? ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
#44
I've read most of these posts and there's no simplified instructions w/much detail. So here I go.
Disclaimer>
But before I begin, a word of caution. Some people can't even talk on a phone and drive, let alone have a movie playing in front of them. Please don't do this if you don't have self restraint and control. If you kill yourself because you were watching a movie behind the wheel, we'll all laugh and call you an idiot. But if you kill someone else, you will forever be branded a murderer. BTW, watching a DVD while driving is mostly likely, illegal in most states. Check with your local law enforcement.
Hopefully, you have had some experience w/a crimper and maybe even a soldering iron. And I really hope that this is not going to be your maiden outting on a $50K Lexus. If you're using a soldering iron, please be careful with it. We charge $150 for this procedure and you may think that it's a lot but you'll be SOL if you burn a hole through your carpet w/a soldering iron. You'll probably kick yourself in the *** for not shelling out a measly $150. Besides, if you drive a $50K car you should be able to afford it. If you can't, you've got your priorities screwed up. Think before you do. We make it look easy because we have experience and experienced people deserve to get paid.
Instructions>
The removal instructions are already posted somewhere. I won't go into that.
There are three white plugs going into the monitor. We will not touch the middle one.
On the far left, closest to driver's side, is 26-pin plug K46.
On the far right, closest to passenger side, is 32-pin plug h1.
On K46, pin # 14 is purple. It is the VSS wire coming in from the BCM to the monitor. Leave a couple of inches on the plug and cut it.
On K46, pin # 23 is yellow. It is the Parking Brake wire that tells the monitor if the parking brake is engaged. Leave a couple of inches on the plug and cut it.
On h1, pin # 13 is pink. It is the VSS wire that leads out to the navigation unit. Leave a couple of inches on the plug and cut it.
The monitor side of the purple wire will be left disconnected. Tape it up or preferably crimp it w/a 3M cap.
The wireloom side of the yellow wire will be left disconnected. Tape it up or preferably crimp it w/a 3M cap.
The monitor side of the pink wire will be left disconnected. Tape it up or preferably crimp it w/a 3M cap.
Use a ring terminal and an 18 awg wire to connect the monitor side of the yellow wire to chassis ground. There's plenty of grounding locations available along the side, where the monitor mounts. Screw or bolt it in securely w/o interfering w/mounting area.
Use butt connectors or tape and solder an 18 awg wire to connect the wireloom side of the purple wire to the wireloom side of the pink wire. You are effectively re-routing the VSS signal directly into the navigation.
Reinstall the monitor and you are finished.
Synopsis>
Now you should be able to watch movies and access the Bluetooth features while in motion. The parking brake indicator light will only come on when the parking brake is actually engaged. And there should be proper VSS signal reaching the navigation unit. All with absolutely no switches needed.
However, this procedure will not bypass the navigation safety feature. You cannot input addresses, etc. while moving.
Obviously, the VSS signal is still reaching the navigation brain and it's sensing movement and locks you out of it's controls.
![](http://img190.imageshack.us/img190/6058/topdownsmall5rp.jpg)
Top down view.
![](http://img190.imageshack.us/img190/4818/plugclosesttodriversmall4kg.jpg)
Plug K46, closest to driver.
![](http://img190.imageshack.us/img190/4250/plugfurthestfromdriversmall9wh.jpg)
Plug h1, closest to passenger.
UPDATE: Sorry, but I've been really busy and haven't been checking my PMs or updating info on here. We moved to a new location awhile ago. The old place was nice but the rent was too high with this economy.
New location
Sound Specialists
8507 Garden Grove Blvd.
Garden Grove, CA 92844
North-East corner of GG Blvd and Dale St. Between Beach Blvd. & Magnolia.
The old number is still forwarded but our new number is 714-530-8779
BTW, we can perform hacks for IS as well.
We also sell and install Parrot Bluetooth kits as well as USASpec & Vaistech iPod integration kits and Vaistech satellite radio kits.
And as some of you already know, we still work closely with Lexus of Westminster.
BYPASS UPDATE: You can temporarily access the Navigation Controls while in motion by installing a toggle switch between the PURPLE & PINK wires instead of just connecting them together. Just flip the switch, input an address, and flip the switch back. Obviously, if you leave the switch closed and the wires are connected, then you don't have to do anything to watch a movie. This switch just gives you the option of inputting an address when you really can't get off the freeway and pull over.
I've been doing this for a couple of years and never got around to updating this post. Sorry but when you're so focused on work, and involved in so many different projects and other forums, I tend to forget things. Again, I appologize. On the upside, this may help a bunch of you out there so good luck and drive safely... but most of all, enjoy!
Disclaimer>
Instructions>
Synopsis>
Top down view.
New location
Sound Specialists
#45
Where are you located? I'd rather pay the 150. Does this work for bluetooth?
Disclaimer>
But before I begin, a word of caution. Some people can't even talk on a phone and drive, let alone have a movie playing in front of them. Please don't do this if you don't have self restraint and control. If you kill yourself because you were watching a movie behind the wheel, we'll all laugh and call you an idiot. But if you kill someone else, you will forever be branded murderer. BTW, watching a DVD while driving is mostly likely, illegal in most states. Check with your local law enforcement.
Hopefully, you have had some experience w/a crimper and maybe even a soldering iron. And I really hope that this is not going to be your maiden outting on a $50K Lexus. If you're using a soldering iron, please be careful with it. We charge $150 for this procedure and you may think that it's a lot but you'll be SOL if you burn a hole through your carpet w/a soldering iron. And you'll probably kicking yourself in the *** for not shelling out a measly $150. Besides, if you drive a $50K car you should be able to afford it. If you can't, you've got your priorities screwed up. Think before you do. We make it look easy because we have experience and experienced people deserve to get paid.
Instructions>
Synopsis>
Now you should be able to watch movies and input commands into the navigation while in motion. There should be no parking brake indicator light on the gauge cluster. And there should be proper VSS signal reaching the navigation unit. All with absolutely no switches needed.
Top down view.
Disclaimer>
Instructions>
Synopsis>
Top down view.
