Tips, Tricks, DIY's, & How-To's
Old 07-01-07, 09:49 AM
  #406
mick6
mick6's Avatar
OK Guys, just got a 06 gs430....tried manual overide and can't get it to work, menu, volume, upper left, lower left,upper left, lower left. did i leave anything out? please help!
Old 07-02-07, 12:41 PM
  #407
timeToy
timeToy's Avatar
You need an "hybrid" DVD Nav ! Check this post
Old 07-06-07, 10:33 AM
  #408
tomzookn
tomzookn's Avatar
Default How to change ODO from miles to KM ?
Anyone know how to change SPEEDO and TEMP to METRIC in 2006 GS300 ???
RM
Old 07-06-07, 02:00 PM
  #409
jerfitz
jerfitz's Avatar
Go here: Enabling the NAV System Features When Driving
https://www.clublexus.com/forums/sho...69#post2503969
Old 07-06-07, 02:08 PM
  #410
noncom23
noncom23's Avatar
Says for ES350. ??OK for GS350??
Old 07-09-07, 02:21 PM
  #411
scubadorg
scubadorg's Avatar
I just got my 07 350GS with all options 2 days ago!
I would like to know are there any tricks to make the side mirrors auto fold after locking the car??? Thanks!
Old 07-13-07, 11:51 PM
  #412
Slexus
Slexus's Avatar
Angry
Originally Posted by phattbam
that simple? why the NEG and not the POS?
Safety!! If you remove positive your tool is on positive in one end and the other end might touch the chassis. You know the story after...
Old 07-14-07, 07:30 AM
  #413
Slexus
Slexus's Avatar
Originally Posted by Sonartech
I have a '07 RX-350. The wife has a spiffy new '07 ES-350. The RX shipped with a version 5.1 Map DVD. The ES shipped with a version 6.1 Map DVD, even though it was only 2 months newer. In addition to newer road and POI data, there are some significant firmware changes as well.
There's a file on each DVD called "Loading.KWI" which is essentially the entire firmware for the Navigation system. The v5.1 Loading.KWI for my RX-350 is 45.8 megs. The v6.1 Loading.KWI for the ES-350 is 70.0MB. Quite a big difference in size for two cars with nearly identical 5th Gen Nav Systems. 25 megs fatter? For what, I wonder? Climate control commands for the ES-350 that don't work in my RX-350 even though the damn owner's manual says they do? Hmmmm....
Here's the point, though: The Nav Override (aka "Over Ride") that you get to via the Volume menu doesn't work on the v6.1 system. It works on all v5.1 system's (USA) that I've seen, however. So Denso dicked with the activation sequence (or deleted it entirely) for the newer firmware. Since I have both DVD's right here in front of me, I dumped both ANSI and UNICODE strings out of the v5.1 file and the v6.1 Loading.KWI file. The text that can be found in the v5.1 Nav Override menu still exists in the v6.1 firmware file, we just need to figure out how to get to it. Sure, it's possible they removed the hook to that particular menu system and just left the code there, but it's also possible they re-mapped the entry for it. Unfortunately, I haven't figured it out yet.
The other concern I had was regarding the map data vs. the firmware update (loading.kwi file). I wanted the new road data and POI updates from the v6.1 Map DVD, but I didn't want to take a chance of flashing my "Overridable" v5.1 firmware with my wife's v6.1 firmware which doesn't allow the override. The solution is to create a DVD-R that has all new v6.1 files EXCEPT the loading.KWI file which you replace with your older, v5.1 loading.kwi file. I made this DVD tonight and it's working great in the RX-350. It displays v6.1 map and POI data, but I still have my nav override capability.
So my remaining questions are these:
  • Do these Denso-based Nav systems automatically update their own firmware when they see a higher incremental update, or does the service department have to instantiate this process manually? What file(s) get looked at for version information? Version.txt, or the actual loading.KWI file itself?
  • If the process is automatic, wouldn't it be possible to change the version.txt file to "v6.11" for example and actually put a v5.1 loading.kwi file on the DVD? Would the Nav system replace the un-overridable code with the older code the does support Nav override?
  • Is there a diagnostic menu item somewhere that forces a firmware reload from the Map DVD regardless of the version?
Obviously, I'm not real interested in finding out that it's a "one-way road" for updating the Nav firmware at the expense of losing my RX-350 override. It's much "safer" to try and make the ES-350 eat the old v5.1 firmware.
Going forward, it would be most helpful if everyone indicated what version of software they're using so we can eliminate confusion like "why this works on this ES-350 but not that one" and the like. People are scratching their heads unnecessarily trying to figure out what they're doing wrong when the software's actually the problem, not the person or the procedure.
Regarding the Phone-book entries. For the RX-350, the Nav Override doesn't affect those options. They are controlled via a separate speed sense line to the multi-display. Instead of cutting the wire out of the jack as suggested in many places, I opted to just remove the pin from the socket so I could replace it later. I just put the removed pin in a bit of heat-shrink tubing and that was that. What you gain is the ability to play with the calendar and dial numbers from the display in motion. What you'll lose is the direct switch to the speed dial display when you press the steering wheel off-hook button. You'll have the press "Speed Dial" to get to that display option now. A small price to pay, I suppose, for the ability to use all the features in motion.
I would also like to state and confirm for the record that Lexus service personnel DO know about the Volume screen Nav Override hack - but they've been told very strongly "not to share that information with the customer." I also know that the same person I spoke with was sincere when he told me he wasn't aware that it had been removed / editied from the v6.1 NavDVD firmware.... so either they haven't been trained on it yet, or it's really, really been removed... which would seriously SUCK! Also, there's no TSB or anything on TechInfo regarding the Nav Override. How'd these guys get told about it? My guess is there's another vector for information release outside of what we, the disgustingly rich public which has to put up with the B.S. lock-outs, can access. Anyone have any ideas? Has anyone actually ever seen an official Lexus guide that mentions this bloody override?
<yawn>
That's my brain dump for now. My quest continues to find out where Denso moved the infamous Override...
ps: If you're a Denso developer reading this message and you're involved in the process of creating these Nav updates, EAT MY SHORTS, Pinhead! I don't tell you how to write code, so don't tell ME how to use my equipment! Remember who's paying the money to keep your stupid %!^@% employed! Now get off your dead stump and fix my RX-350 climate control voice commands!
Yours in sickness and in health,
SonarTech
I would love to do the mod without tammping the wiring. I only need to fool the sensors input to the NAV unit in order for voice guidance to work.
I hav E7009 Solara 5th Gen nav unit (not install to the Sienna yet, awaiting for other parts), I need to fool the Park, Reverse and Speed sensors inorder to get voice guidance for my 2007 Sienna LE. The problem is I do not know where are the sensor pins from ECU units, and I do not want to tap these sensors if I don't have to by trying to input dummy signals to the unit.
Please help me so far I found the 2 expected, Park and Reverse signal outputs from ECU (not locations). Do you know the wave form signal of the Speed sensor out put from ECU? Thanks a bunch.
More research, I found this in the mp3 forums.
Label, Color, Pins, Toyota P/N (My own description of the connector)
Pin Color Signal-Name Description
R9 Gray 5 90980-11909 (Sensor signals)
1 Green PKB - Parking Break. This signal is grounded when parking break switch is closed. Floats otherwise.
3 Violet/Red SPD - Generated from the Speedometer. Most likely this is the Vehicle speed sensor pulse line.
5 Red/Yellow REV - Reverse Signal. This signal is tied to +12v when the Park/Neutral switch is closed.
I think we can feed the Navigator inputs:
-Ground for parking break
- +12V for Park (go thru a resistor to limit the current etc..)
Question is: without SPD input will the unit works for voice guidance? I do not care, or worry about if nos SPD sensor it will not calculate when under bridge, tall building or tunnel.
Thanks.
Old 07-19-07, 08:10 AM
  #414
Kuzyn
Kuzyn's Avatar
how much whould any you want for a copy of the 6.1 dvd upgrade let me know i really could use it. Thanks.
Old 07-19-07, 06:18 PM
  #415
business1s
business1s's Avatar
Originally Posted by noncom23
To amend my previous post above. I got the seatbelt buzzer off with this link from Sonartech.
Thx!
http://forum.ih8mud.com/showpost.php...77&postcount=2
worked for me also. Thanks!
Old 07-19-07, 06:20 PM
  #416
noncom23
noncom23's Avatar
Cool!
Old 08-03-07, 07:45 PM
  #417
gonzalu
gonzalu's Avatar
Any news on override for 6.1 DVD navi? I am on a 2008 RX-350 and I am REALLY annoyed at not being able to use ANY controls worth using while moving.
In the city is not that great a problem... usually stopped at trffic light often... but on a recent trip to Albany, I was HELD HOSTAGE for over 3 hours... it SUCKED! GRRRRRRRRRRRRRRRRRRRR!
Thanks for letting me vent...
Cheers!
manny
Old 08-04-07, 08:11 AM
  #418
Cut-Throat
Cut-Throat's Avatar
Cheers!
manny
Yeah the news is: The hack that is outlined in this thread works great! - No more GRRRRRRRRRRRRRRRRRR!
Old 08-04-07, 09:35 PM
  #419
jerfitz
jerfitz's Avatar
Manny,
Go look here. Enabling the NAV System Features When Driving.
JerFitz
Old 08-12-07, 04:48 PM
  #420
ES350lexus
ES350lexus's Avatar
Thank You Sonartech
I got my Hybrid DVD to work using your instruction.
Quick Reply: Tips, Tricks, DIY's, & How-To's
