turn car off but put in accessory mode?
Hello,
Maybe you can tell me how to turn the engine off without turing off power to the entire car? Example, driving and using the car to make a phone call via bluetooth. Arrive at my destination, but not done with the call. I want to turn the engine off, but not drop the call.
When I hit the start button, the whole car turns off.
How do I turn the engine off without losing power to accessories like the nav, radio, and bluetooth components?
Thanks,
Lonwa
Thanks,
Lonwa
just one quick question. are you guys sure it won't be damaging to the transmission or whatever underneath. i tried this once, and it worked like what you guys said, but a few seconds later i heard a click and saw the shifter moving into P position (as if it were locking in). i used to have an Infiniti EX35, where i took up on the buyback offer, then i got the GS350. on the EX35, all you had to do was hit the push start button twice really fast and it'll be back on accessory mode, but would have not turned off anything except the engine. i tried that with the GS and it did not work, everything just turned off. that was one good feature of that car. as a matter of fact, i was on the bluetooth, got home, and inorder to not drop the call, i sat there for an extra minute with the engine running to finish up the conversation.
as long as the car is fully stopped already and it's in N, shutting it off wont' cause any issues. and you are saying you put it in N and the shifter goes to P ITSELF? man, that sounds very creepy!
sorry i should have been more clear. what i meant was the car is stopped in neutral, i shut off the car, and then move the shifter to P, press the parking brake, and then let go of the brakes. about 2 seconds later, i hear a click and see the shifter move towards the left just a bit more (even though i fully put it in P, not like i moved it half way).
Wouldn't only the engine shut off only, leaving everything else on (ie gauge cluster and everything still lit up). Kinda like pretending to start the car again when the car is already running.
Actually, to minimize putting undue stress on the parking pawl (device which locks up the transmission) you should turn off the car while in Neutral, then first set the parking brake, then take your foot off the brake pedal, let the car fully stop (especially on a slope) then put the car in Park. Using the parking pawl to keep the car from moving is not a good idea that's what the parking brake is for.
if the car is running, no matter if your foot is on the brakes or not, if you press the start button, the whole car shuts off, including gauge cluster, radio, nav, etc...
