Quick wire and trim removal question..HELP
Old 01-16-09, 01:23 PM
tunedis95
tunedis95's Avatar
Default Quick wire and trim removal question..HELP
trying to hardwire my valentine radar
which of the is power and ground??? These are the wires going to my mirror
and/or how do you remove this piece..i want to get my ground in there.
Old 01-17-09, 06:37 AM
BurgBoxstr
BurgBoxstr's Avatar
Not sure but you should be able to find out using a multimeter. As an alternative, here are some other directions on taking the power off the cigarette lighter and then just tucking the RJ11 wire behind the trim:
V1 Install Using Cig Lighter
Old 01-17-09, 02:47 PM
tunedis95
tunedis95's Avatar
anything on the trim piece...i couldnt find my volt meter thats y i was asking...i rather not run the darn wire all the was through everything...ya know..rather run 1 ft worth and thats it...
Old 01-18-09, 08:23 AM
BurgBoxstr
BurgBoxstr's Avatar
I'm not sure which trim piece specifically you are talking about but I do recall other members wiring off the mirror. Do a search on the following terms and you should find what you need:
hard wire your radar detector
or
Hardwired Passport X50 to my new 3GS
Old 01-18-09, 07:07 PM
Arantant
Arantant's Avatar
I really really wish I had taken some pictures while installing mine. I actually followed instructions I found for the 2IS and it was pretty similar for the 3GS. There is a pretty long thread in the 2IS forum:
https://www.clublexus.com/forums/is-...full-post.html
Look in the posts only about using power from the mirror... lots of info there...
I do recall the wire colors were different on my car than the 2IS... I forgot to note them down. I had taken off the top part and had direct access to the wire connector from the mirror to wherever it's supplied from and I used that in a trial and error (by touching the two wires to different parts of the connector until I figured out what worked.
I don't want to risk opening it all up again for fear of doing any damage to the trim pieces, but here are some pics of what my completed install looked like:
Old 01-18-09, 07:46 PM
Loxus
Loxus's Avatar
Looking good!
westopill
09-09-19 05:25 AM
Groober
07-27-17 06:42 PM
mick5410
04-12-12 07:53 AM
scottsRX
07-26-04 07:59 AM
Quick Reply: Quick wire and trim removal question..HELP
