Tires rubbing?
19x 9.5 +25 all around - 245/35/19 all around. I hear screeching on bumpy roads from the rear of the car.. first I thought they were the Eibach springs.. not sure if its tire rubbing noise tbh.. punctured one of the front PSS tires today :/.. does rubbing play a factor in this??
Former Sponsor
Did you shave or roll fenders? Have you turned the wheels and seen if the tires have scraped the plastic fenders? You might need to take off the plastic in the rear of the car or shave fenders in the rear. Is anything cutting the tires?
Please post some pictures of your setup! A picture is worth a thousand words!
I had this problem because of my offset. Serious rubbing on every bump after installing my 10mm spacers.
Your wheels must have the correct offset for your GS. Otherwise, no matter what teh wheel width or ride height, you will rub especially at the rears!
This was my tires after rubbing, mine rubbed on the outer liners! Yours could actually be rubbing on the inner!
![](http://i23.photobucket.com/albums/b364/Ahmed--Baqer/Tire2.jpg)
![](http://i23.photobucket.com/albums/b364/Ahmed--Baqer/Tire1.jpg)
executive matchup
Rider, take your car to Lexus body shop in Salmabad. Ask for Tareq, he's a guru when it comes to fender rolls and suspension adjustments. Not forgetting that they are actually authorised Lexus dealers!
If you don't wanna mess with your fenders, you can try to sell your wheels and buy mine! They are perfect and do not rub with those Eibachs.
Let me know if you need any help bro! I'm here for ya!
