Old 12-16-14, 10:54 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
Light Bulb Size Diagram - 3GS
Old 08-15-11, 09:09 AM
j0emama
j0emama's Avatar
Default Light Bulb Size Diagram - 3GS
Since this is a very common mod and people are always questioning light size, here is a quick cheat sheet for the most common replacement bulbs.
2007 Lexus GS350 Car Light Bulb Size Diagram
Headlights/Low Beam Headlight Bulb Size: HID-D4S
DRL/High Beam Headlight Bulb Size: 9005
Parking Light Bulb Size: 2825 (194/168)
Front Turn Signal Light Bulb Size: 992 (7440A)
Rear Turn Signal Light Bulb Size: 992 (7440A)
Tail Light Bulb Size: LED
Stop Light Bulb Size: LED
High Mount Stop Light Bulb Size: Assembly
Fog/Driving Light Bulb Size: 9006
License Plate Light Bulb Size: LED 194 168 158
Puddle Light/Mirror Undercarriage: 194
Back Up Light Bulb Size: 921
Front Sidemarker Light Bulb Size: 2825
Map Light Bulb Size: 175
Trunk/Cargo Area Light Bulb Size: DE3021
The following 2 users liked this post by j0emama:
skur (06-16-23), UCFdude (06-23-24)
Old 08-15-11, 02:31 PM
krschee
krschee's Avatar
strong work.
so DRL and high beam are the same bulbs? and installing an LED renders the high beam inactive?
how do DRL and parking lights differ?
thanks
Old 08-15-11, 02:41 PM
j0emama
j0emama's Avatar
Originally Posted by krschee
strong work.
thanks
Correct, DRL/High Beam is same bulb (just at different voltage) and LED replacement will inactivate your high beams (not recommended). I personally just had my DRLs turned off at dealer (no charge from dealer).
"Parking lights" are in that same housing but in the top corner vs dead center for DRL/High Beam light. They go on when low beam headlights are activated.
Old 08-15-11, 02:50 PM
JH48
JH48's Avatar
for License plate led 168 or just any
Old 08-15-11, 03:01 PM
j0emama
j0emama's Avatar
License Plate: LED 194 168 158
Those should work fine.
Old 08-15-11, 04:33 PM
1scGS450h
1scGS450h's Avatar
Nice!! just what i needed!
Old 08-15-11, 04:55 PM
Stormforge
executive matchup
Stormforge's Avatar
this should be included in the 3GS FAQ sticky....
Old 08-15-11, 05:47 PM
masterchri
masterchri's Avatar
ha ha i was just searching for something like this ! Thanks!
Old 10-02-11, 04:25 PM
fluffybear
fluffybear's Avatar
thanks for the info...
Old 10-03-11, 07:18 AM
rajmichael
rajmichael's Avatar
good stuff, can I change my parking lights to LEDs and if so which part# is the best replacement? or should i just go with a sylvania replacement? don't really care for the dim orange look of the parking lights that come stock. also want brighter foglight bulbs
Old 10-03-11, 07:52 AM
rajmichael
rajmichael's Avatar
not feeling the lights a little help pls.
Old 10-05-11, 11:32 AM
j0emama
j0emama's Avatar
Parking light replacement bulb size is 2825. If you replace it with a sylvania and stick with halogen you won't get much of a difference in color. It's a very simple LED replacement.
Old 10-05-11, 11:35 AM
j0emama
j0emama's Avatar
What did you want to replace? Headlights are pretty simple swap out for any color since they are already HID. I switched my fog's to LEDs to match my headlights, although they are pretty useless emitting any visable light. For that you would have to get an HID conversion kit.
For the center housing parking light = easy swap, but the DRLs your stuck with unless you don't mind disabling your high beams.
Old 10-05-11, 12:14 PM
BAUSauto
Former Sponsor
BAUSauto's Avatar
Nice find!
Old 10-06-11, 05:07 AM
passnu2
passnu2's Avatar
done
Quick Reply: Light Bulb Size Diagram - 3GS
