GS350 Water Pumps
Just as preventive maintenance I went ahead and replaced my water pump. I went ahead and purchased most of the parts from Ebay total in parts it cost me $163.00
Thankfully I caught it right in time, when I pulled the water pump pulley the inside was coated in red coolant gel. I always checked the coolant level and was always good. So if you have over 70K miles I would check or replace the pump, before it does some serious damage.
Aisin (OEM just named different) Water Pump, with gaskets: $110.00 shipped
Serpentine Belt Bando (OEM just named different): $21.00 shipped
Idler pulley Gates (should have went OEM): $32.00 shipped
Total time took 2 hours, fairly easy install
As you can see the dried coolant that leaked out of the pump created a thick crud
![](https://imageshack.us/a/img254/7508/img2319n.jpg)
Aisin is the OEM pump heres a comparison
![](https://imageshack.us/a/img838/4615/img2327l.jpg)
As you can see, Aisin grinds down Toyota off there parts
![](https://imageshack.us/a/img823/6167/img2328w.jpg)
lttlLater (05-25-20)
Is it easy or do you have to remove some things to access the water pump? And can you take picture of the area from a DIY perspective? Starting to see water pump failures and what not and certainly don't want anyone with a blown engine which could have been prevented by an easy fix. Thanks OP!
I did take pictures, I just haven't had the time to go through them and make up a write up.
You will not see these parts on Sewell because they are aftermarket parts. These are the aftermarket supplier that toyota use for there OEM stuff. So basically you are buying a toyota part with a different name on it.
Heres the serpentine belt I used
http://www.ebay.com/itm/300515556569...84.m1497.l2649
Heres the water pump
http://www.ebay.com/itm/310536493569...84.m1497.l2649
HenryHYee (07-28-21)
http://www.clublexus.com/forums/gs-t...placement.html
