Auto Folding Mirrors on GS
Finally, I did it....comments and complaints are welcome
Took me couple hours for both side
Here's the instruction I got from Russian guy who did on his GS
1. Remove driver side door panel
You can find the black “Mirror Control Unit” which has 3 Connectors
Connector A, Connector B and Connector C
![Name: 1_zps08fac139.jpg
Size: 98.0 KB](https://www.clublexus.com/forums/attachments/gs-3rd-gen-2006-2011/427305d1501327512-auto-folding-mirrors-on-gs-1_zps08fac139.jpg)
2. At connector C
Cut the green wire (pin #3 on connector) now you have
- Green wire (connector side) and Green wire (Motor side).
- Do same with blue wire (pin #11 on connector).
Green wire (connector side) connect to Pink wire of PO-40.
Green wire (Motor side) connect to Green wire of PO-40.
Blue wire (connector side) connect to Purple wire of PO-40.
Blue wire (Motor side) connect to Yellow wire of PO-40.
When You done you can plug the connector back to the Unit
![Name: A_zps46986359.jpg
Size: 209.6 KB](https://www.clublexus.com/forums/attachments/gs-3rd-gen-2006-2011/427306d1501327512-auto-folding-mirrors-on-gs-a_zps46986359.jpg)
3. Unplug Connector B
-Tap the Black/white wire on the connector (pin #1 on connector) with Black wire of PO-40.
-Tap the Yellow wire on the connector (pin #3 on connector) with Orange wire of PO-40.
-Tap the Blue wire on the connector (pin #6 on connector) with Red wire of PO-40.
When you done, you can plug back the connector to the unit
![Name: B_zps4ac68bcf.jpg
Size: 225.6 KB](https://www.clublexus.com/forums/attachments/gs-3rd-gen-2006-2011/427307d1501327512-auto-folding-mirrors-on-gs-b_zps4ac68bcf.jpg)
4. Unplug Connector A
-Tap the Red wire on the connector (pin #1 on connector) with Blue wire of PO-40.
-Tap the Green wire on the connector (pin #2 on connector) with White wire of PO-40.
When you done, you can plug back the connector to the unit.
![Name: C_zps9ab149cc.jpg
Size: 183.9 KB](https://www.clublexus.com/forums/attachments/gs-3rd-gen-2006-2011/427308d1501327512-auto-folding-mirrors-on-gs-c_zps9ab149cc.jpg)
That’s it, driver side Complete, for the passenger side the color little different, but if you use the pin location should be same position.
Another note, there is 2 version of PO-40, make sure you order the older version (Old version has brown loop cable, new version use plug for brown cable)
2. At connector C
Is there any preventative maintenance that we can do to the mirrors to keep them lubed?
Can the mirror gear assemblies be serviced reliably without damage? I would be fine with this if the mirrors were more reliable.
executive matchup
