Rear Axle Whine
Old 08-25-22, 04:27 AM
  #31
NTH
NTH's Avatar
Yes GXs are AWD.
Vehicle is actually super smooth and stable on stands under rear axle and front frame and 2 additional jacks under A Arms just enough to relieve angle. Check out Esco stands. There’s options for axle and flat tops for the frame. It’s the only way to rule out third member/pinion noise.
Old 09-04-22, 07:38 AM
  #32
BzzrBeater
3rd Gear
BzzrBeater's Avatar
These are all good points. I did get the trans fluid changed back when I purchased the vehicle in November. Since then, I’ve learned there’s a difference between draining and refilling and flushing the fluid. I’m unsure which was performed. I’m also unsure if there was metal in the fluid. Wish I had a space to perform this maintenance on my own but until I have a garage I have to use a shop. Next time I’ll be sure to ask for pictures of the fluid.
I’m fairly sure the vehicle was never used for towing, so I doubt the gears are in bad shape. I did schedule a replacement of the pinion bearing, but perhaps I’ll ask if they actually ran the vehicle at 60 mph on the lift before I go through with it. The tech seemed pretty convincing. He’s seen these bearings go bad on several 4Runners, including his own (which resulted in it completely failing when he towed a boat). According to him it results from a bad diff design by Toyota, where the oil does not get circulated well enough to the pinion bearing.
Old 09-06-22, 02:20 PM
  #33
Lexus4321
Lexus4321's Avatar
If you re-grease the U and slip joints well, does the noise change at all?
peterls
05-10-14 07:37 PM
itsZep
GX - 1st Gen (2003-2009)
39
08-26-08 11:48 PM
mitsu
12
10-28-03 01:18 PM
zoombie99
16
10-12-03 11:04 AM
Quick Reply: Rear Axle Whine
