Hi / Lo shifter vibration
Should the Hi lo shifter have a constant vibration. I know the GX is 4x4 all the time but the vibration in the shifter does not seem right. I also feel the slight vibration in the steering wheel and gas pedal when I accelerate. Is the hi / lo shifter vibration normal?
The shifter **** is normal, any 4x4 truck I have been in with a similar stick shift type shift **** has vibrated, if you have a chance look in a Jeep Grand Cherokee, they have a shift lever that is like an automatic shifter and it does not vibrate but the 2 designs are different, once you see them/it
As for the wheel/gas pedal vibe, seems some it does not bother and others it does, I wear boots most of the time but even in my Allen Edmonds I don't really notice it.
