GX470 H11 Xenondepot kit installed DIY guide
#301
Originally Posted by mkool
To. JWS3 and llcc1975,
Finally I got my kit right now. Awesome.
I downloaded the instruction from xenondepot but I have a few questions...Like I have 4pc of bracket. How do you mount with ballast? And did you plug all wire to ballast b4 mount the bracket or after?
If you take some pics it would be great help.
Thx.
Thx.
Sorry, I'm so bad with pictures, I just took mine apart again yesterday to put on the brackets but failed to take pix. Do you have pix of these 4 brackets?
#302
Oh What I mean is the 2 "T" shaped metal brackets, the 2 rectangle metal brackets. How did you mount with ballasts?
Sorry, my bad English.
Here is pic.
Here is pic.
#303
Hmmmm... My brackets were a bit different than (m)
Here is pic.
Here is pic.
However, it looks like the left bracket goes on AFTER the wire is in. The "cut out" at the upper right corner likely fits over the rubber boot and forces it down when the screws (2 at the top & 1 at the bottom) are tightened. The "T" shaped bracket is a mystery, but my best guess is that its an attachment bracket. See how the "T"' screw holes match up with the brackets? I'll bet that one can attach this bracket to the car & then attach the ballast to the bracket. Or, perhaps its a backing plate of sorts to help hold the screw in.
I may be blind, but where on the XD site are the downloadable instructions? Do you have a link? Perhaps I might be able to decipher it. Did you call XD? They are generally very helpful and then some.
Hope this all helps.
Jim
#304
http://www.xenondepot.com/images/Manualls/xdman.pdf
above link is all I got for manual. doesn't say much about the installation. Said how to connect between ballast, igniter and bulbs. With cautions. That's it.
That is why I askin what's up with barckets.
Question;
1. on passinger side, where can I connect negative line to?
Question;
#305
Question;
Question;
The T-shaped brackets are a mystery to me also. I tried playing with it for almost 15 minutes and could not figure out how they attached. I'll echo what JWS3 said in that it could just be an additional piece that is used for mounting flexibility. I did NOT use the T brackets however, and just inserted my zipties through the space that was left in between the bracket and the ballast itself when they are screwed together (you'll see what I'm talking about) as when you install the brackets, any open screw holes (which I originally used to insert my zipties through) will be used up for the bracket itself.
As for instructions, my kit, like yours did not include any sort of instructions. The only thing that came close was the URL link to that PDF from their website.
As for where to connect the ground on the passenger side, I'm not sure what year your GX is, mine is a 2005 and I had a home run grounding bolt (with a bunch of other wires coming into it) that is right on the inside panel (about same position as the same type of bolt that's on the drivers side). In fact they look identical.
#306
Thank you both of you helped me out for installation......I'm done installation, now I have a XENON HID LIGHT....
It's kinda earily to see full light output but nonetheless it looks awesome...
Did I mention that I got a 6k Xenon light?? hehe~
It's just like my BMW, and M-Benz's HID light....
And Steve, thanks all your service...I love your kit, I recommend everyone whom want the HID.
Thank you, Xenon Depot
#307
Former Sponsor
Hello,
If anyone would like pictures of how to install the brakcets please email me and I will gladly forward them to you.
Cap,
HIDs operate on less power however upon startup they do draw significantly more power. This is why we prefer to power the ballasts directly from the battery as opposed to the OEM headlight harness.
Steve
Cap,
Steve
#308
#310
Originally Posted by Capirato
Steve.....
The extra draw in power is only momentarily. The HIDs in my GX are powered directly from the OEM harness. Have had absolutely no problems for almost three years.
~ Cap
~ Cap
So do you have the XD kit installed but are somehow powering them from the OEM harness vs. the battery?
What's your setup. I'd like to know if there's an easier, proven, solution.
Thanks.
#311
To. Steve,
I have some questions.
1. When I turn my HID light on, I hear sound from the ballast. Is it normal?
2. When I drive over the bump (small or big), I see, light is flickering(sp?) once (depands on how many bumps I passin). Is it normal?
Thx
Thx
#312
I am not Steve, but a hum on start up I believe is normal. (m)
To. Steve,
Thx
Thx
Suggest you call him directly. There is a ph number on the web site.
#314
Originally Posted by XenonDepot
Hi mkool ,
I would double check all your connections. Flickering is not normal.
Steve
Steve
#315
XenonDepot 6000k HID light conversion complete...
I just put these in my '99 RX300 last night and wow, they are awesome! Very bright!
Although, I must say the 9006 lights for low beams don't seem to fit into the 9006 slot on the vehicle like the factory lights do. There are 3 grooves (2 bigger ones and 1 smaller one) on each light, just like factory, and I can seem to get 2 in the slots when I put the lights in, but the 3rd doesn't want to fit in correctly. Therefore, they are not secure and "snapped into place" how the factory 9006 lights do.
I can get them in wedged in, where 2 grooves are in, but the 3rd is kinda sticking out, and I think this causes my lights to be shining up higher and on the trees a little bit more than they should. I can literally see drivers oncoming inside their vehichles...and I know that is not right.
Anyone have any suggestions since these lights are not fitting in how they should? I know they are the right size. Has anyone installed these 9006 6000k Xenondepot Xenon lights in their vehicle?
I posted this in the RX300 forum but no one can really help there. I don't think anyone has installed them in the 99 RX300 model.
Thanks for any help!
Chris
Chris
