need help asap (height control reset)
need help asap
i installed aftermarket rims today and also trensfer the tire pressure sensors to the aftermarket rims too. but now when i go to use the height control in the rear it goes to the position but the second i start driving it goes back to neutral. do i need to have it reset because the tires are at a different psi and the computer thinks something is wrong?? is that why it wont stay set??? any assitance would be great.
thanks
thanks
That's totally normal. Even with the original wheels, the car will go back to its "Neutral" height as the car passes a set limit. As of yet, there is no way to bypass this automatic feature.
cyberflip
cyberflip
whats the set limit?? time?? then what is the purpose of this feature if you cant use it?? or does it only really work if you are towing something and it detects the extra weight on the shocks??
