Disconnecting the battery & your power windows
Just posting to let everyone know b/c we found out the hard way last night. We actually got a little worried that there was a real problem, and then after much searching we found the answer. This is in your manual, but as we found it can be difficult to locate.
If you disconnect your battery your power windows may not work properly after you reconnect it. They will have to be "normalized". It's quite strange. All of the auto functionality will not work, the buttons on the driver door for the passenger and both back windows will not work, and the little green light will flash twice, then wait, then flash twice, then wait, etc. The way to remedy this is to roll all windows up, then one by one roll them down, up, down, up, hold for 5 seconds. Each button will stop blinking as you go through, but you must do all of them for the driver door buttons to be functional again. There is no particular order to which door to do first.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
t2d2
09-15-16 05:02 PM
mostrogt
07-23-06 03:39 PM
andy2003si
01-24-05 10:33 AM
