Interesting Issue after installing XenonDepot HID's
I had to remove the Proxenon Kit from my GX because the lights wouldn't stay in the socket. In fact one of the bulbs began to melt the H11 socket
Everything came out fine. I choose to run the wires near the firewall instead of by the radiator. Didn't want the wires in the way of anyone servicing the truck, plus I felt it would be cooler near the firewall up tight inside that plastic panel.
When turning the lights on (while the vehicle is started), my undetectible K40 radar detector bleeps like it's starting up for the first time. Is it possible that the startup load of turning these lights on is dropping the voltage down enough to make some devices reboot (my K40)?
I don't remember a necessarily large fuse for connection to the battery to the kits relay, so I'm perplexed that these lights could be drawing too much.
Anyone have similar issues?
Is this the Proxenon hit or the Xenon depot kit?
I know in the title of the post it says xenondepot but then you say proxenon kit in the first line of the post can you let me know which one you are talking about. I just ordered a xenondepot kit and i may cancel the order if this is xenon depot. thanks.
Re: Is this the Proxenon hit or the Xenon depot kit?
Originally posted by electro992
Sounds like you somehow wired in incorrectly.
I'm connected directly to the battery.
Kbach? What kind of radar detector? I''m using a K40 Undetectible with LED's mounted in the dash. The unit is Front and Rear Radar and Laser Unit up front.
Originally posted by looknow12
Nothing is wired incorrectly. The biggest thing about this kit is to supply it with 12VDC Positive directly from the battery. If anyone tries to connect directly to somewhere inline instead of the battery, that will definitely cause an issue.
I am using the ProXenon kit on my 04 GX. It does NOT connect directly to the battery. It does NOT have a relay.
Each ballast connects directly to the power source of the original low-beam headlamp. Each low-beam headlamp circuit has it's own 10 amp fuse. Each ballast draws less current than the original lamp.
~ Cap
Originally posted by Capirato
Hi Looknow.....
~ Cap
Hi Looknow.....
~ Cap
For the record, I am not referring to Proxenon Bohmen HID's. That kits going in the garbage.
humm thats kinda shady... i thought that xenons burned cooler then regular hallogen bulbs...
i'll take a look at my houseing sockets.. and i dont notice a power surge when my lights turn on.. maybe theres something wrong with your ballasts.., the ballasts should store power so they dont surge your system, thats the point.. dunno.. you might wanna e-mail steve.
hopefully everyone else with the XD kits will chime in also
On the other issue, I noticed the socket was burned when I took out the Proxenon bulbs. This most likely occurred because the damn bulb wouldn't stay in place, so the rod that attaches to the bulb I believe was pressed against the plastic socket housing. (The melted socket is not a XenonDepot Issue).
Yes, that might be the case. I definitely agree, and like the fact that they use a relay direct to the battery. All heavy duty systems that draw a decent amount of amps use relays.
bobinsofla
GX - 1st Gen (2003-2009)
11-12-08 10:53 AM
