Glove Box Misalignment/Rattle
Hi folks, first time posting... I did a search on this topic, but found nothing.
I have a slight rattle on my 9700G coming from the glove box. When I look at the glove box, I can clearly see that it is slightly misaligned. On the side closer to the driver, I can push it in and make it even with the passenger side. Basically, the box is fully seated on the right but not on the left. This is the cause of the rattle.
I was wondering if any of you have had this problem and have been able to address it yourselves or had your dealer tackle it. I have no problem mentioning it to the dealer, except that with all that nice wood around the glove box, I get a bit paranoid about anyone using tools around that area...
Thanks!
Thanks!
I don't have the problem and own a 9700G. If I were you, I would let the dealer handle the issue. If you cause further damage, you risk assuming the entire repair cost. If the dealer damages the wood, they would have to repair that, as well.
