Rear Entertainment Display fuse?
Can anyone tell me if they know which fuse is responsible for the rear screen? I cannot get my to turn on. I have tried radio 1, radio 2, acc, IG1, and one other. But I still cannot find a blown fuse.
I've done some mods so I'd prefer to not take it back to the dealer unless it's absolutely necessary.
Re: Rear Entertainment Display fuse?
Hope this helps.
~ Cap
Re: Re: Rear Entertainment Display fuse?
Originally posted by Capirato
When I was having an After Market DVD player installed, the Nav Screen would not come on. After checking all known places to check, I drove the truck to a Lexus Dealer. They found a blown fuse under the hood in the fuse compartment behind the battery.
Hope this helps.
~ Cap
Hope this helps.
~ Cap
Thanks
Electronic Control Unit
It is the factory rear entertainment screen that's not coming on. And I need to know the exact fuse number (if anyone knows it) cause I reviewed the reference book and it's not clear enough to figure out what fuse the rear display covers.
Thanks
Thanks
~ Cap
Re: Re: Re: Rear Entertainment Display fuse?
Thanks
Thanks
~ Cap
Re: Re: Re: Re: Rear Entertainment Display fuse?
In the fuse compartment under the hood on the driver's side, look for the fuse maked ETCS. I'm guessing that it's for the Entertainment Center.
~ Cap
~ Cap
Thanks Cap
Looknow,
Silly question for you, but please bear with me. Is this a brand new GX??, i.e. have you used the DVD system before? If not, you can only turn it on with the remote. I found that out the hard way. Could be the batteries are dead in the remote too. If it's worked before, maybe you do have a blown fuse.
Hope that helps.
Hope that helps.
