DIY Oil Change
DIY Oil Change
Owner of a 2005 White GX with Nav, DVD. Hated to wait until 5k for oil change.
Using KN filter and Mobil1 changed today at 1,938 miles.
Getting to drain plug simple, with 4 bolts needing removed.
However, as to the filter would you recommend trying to get at it from the top and snaking it out, or alternately removing the second "skid/protection plate" which requires a number of bolts being removed?
Thanks in advance, and no I don't have clunks, rattles, car is perfect so far. In fact considering the purchase of a second one for wife, although MDX may win out due to $10,000 differential.
I've been told that it may not be a good idea to change oil too frequently due to the many detergents added. Of course, Jiffy Lube (which is AWFUL) would disagree! I guess whatever makes you happy!
Lexus/Toyota do not use any special break in oil, you waited for nearly 2000 miles to change the oil, should have done it at 500 or 1000 but then again I don't keep the vehicles passed 60k so why change it, whats it gonna last to 450k instead of the 500k it suppost to
Keep an eye on your oil level, the M1 burns out for the 1st 10k, no more then half a quart but it will stop
To get to the drain plug, you DONT have to remove any bolts. There is a plastic cover in the skid plate for access. As for the filter, it takes 5 min to remove the 4 bolts that hold the front skid plate. The filter drops right out of the bottom.
Thanks, I ended up taking the back plate off, missed the "hatch".
As to the earlier comment I don't see how changing oil "too often" can hurt. It's an economic and an emotional decision, could not get to at 1,000 and did not want to wait until 5,000.
Now may do the free change 5,000 at 6, then every 5.
Anyone have experience what a dealer may charge at the 5,000 as an upcharge for using Mobile 1?
Mobil 1
~ Cap
oil filter
i'm gonna change my oil this weekend and want to know how to get to the oil filter. do you remove the skid plate that bolt into the front bumper in order to remove the plate under of the filter? or can you just remove the skid plate right under the filter without remove the one that bolt into the front bumper? and also do you use toyota oil filter or mobil 1 oil filter . thanks
I remove the skid plate directly under the oil filter and remove the plate versus letting it hang on the built in hinge. I actually had to jack up the front a few inches to get the skid plate off. Much neater this way. There is a plate and a lit mounted below the filter which will channel the oil into your pan neatly...very nice touch!
Oil has many additives including detergents and in some cases lubricity, antiwear, and base/alkali additives. Everytime you change your oil, you replenish the additive package as well as refreshing the oil. More frequent changes will not harm your engine.
One problem with the synthetic oils is that it sometimes lulls the owner into feeling that the oil is still OK because it hasn't broken down and still feels slippery (whereas a conventional oil would have broken down and "thinned") so owners wait for long periods of time before giving in and changing their oil. However, the additive package in the synthetic may have been consumed; therefore, the oil will not protect as well as it should.
Having said that, I heard on Cartalk on NPR that Mini Coopers only change their engine oil every 10,000 miles.
I use a Fram PH3614 oil filter, which is the same as the one that the 4Runner uses. Walmart carries this.
Plate removal for filter change
I've been doing my own oil changes for 30 years, and I can't figure this out.
On my 2006 GX, the metal plate in question is attached (via 2 screws and a plastic rivet) to a plastic plate connected to the bumper. How do you remove the metal plate given that it's attached to the plastic plate (I can't figure out how to remove the plastic rivet).
Also, how do you jack up this vehicle for the oil change??? I can't seem to find a convenient jack point with all of these $%#@ plates hanging around.
Mobil 1 can last much longer than 5k
[QUOTE=kurtman]
Mobil 1 is used in Porsche and Mercedes AMG FACTORY FILLED/ Land Rover recently completed round the world trip using Mobil 1...... oil does not need to be changed for 10-15k+...-the base oil used in it is SYNTHETIC and not mineral like most other oils....so it is combination of SYNTHETIC OIL + ADDITIVES that gives you the protection.
On my BMW, manual recommends 15K changes but I change 7.5K or every 6 months - -for GX470, will do it at 5K only to keep the warranty intact although it can easily go much longer -
