HID Conversions
#91
Originally Posted by Capirato
Hey Tony.....
You are mixing Apples and Oranges. If you had said that you got a GX loaner with 4300K HIDs, then you would have a true comparison.
There is no doubt, that the 6000K are brighter, but they give 20% less lumens than 4300K.
I do realize, that some folks like the bluish light better. I have 6500K and I like them too, but would rather have the 4300K for more light. At my age, I need all the help I can get.
~ Cap
![](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
~ Cap
#92
Finally, its done... I got the installs done -
- LOWS --> 4300k H1 HIDs
- HIGHS --> 3500k Sylvania Superstars 9005 ST/2
- FOGS --> Hoen 55W xenonmatch H3
Install was neatly done. Had to drill a hole at the center of the bulb cover to run the wires through to the ballast, otherwise everything was real tight, snug and very well done
Pictures to come.... Here is a teaser (the yellow turn signal/corner light needs to go... need some super bright white on there too, hehehehe)
LOWs and FOGs now bright white instead of the yellow Halogens.
#97
Hi there,
I am looking into purchasing an '03 LX470 as well... and I was wondering will this retrofit from Xenon Depot... void any warranty?
and also is it possible to have the RX330 xenons completely put into the LX lens?
What about the '06 landcruiser? it probably doesnt have xenons either right?
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
#98
Originally Posted by lexxtasy
Hi there,
What about the '06 landcruiser? it probably doesnt have xenons either right?![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
I don't believe the RX330 lens can fit onto the LX470.
The '06 landcruiser does NOT have HIDs like the LX, its headlight design is mightily different to the LX, and so is the part # for the LOW beam bulb/harness.
If you need more info, send me a PM.
#100
Not to beat a dead horse on the head yet again but... here are some thoughts...
Well first off I am sure the Xenon Depot kits work wonderfully as the ballasts look indeed to be the Philips Ballasts that both Sylvania and PIAA use in their kits (as well as in OEM ). However, it is quite possible to get similar results with other kits at around $260... while I think $360 is ok for a true PHILIPS 4300k I think that $460 for the 6000k is way too much...
Now I have installed a kit different from Xenon Depot, though in retrospect I would prefer to go with a Philips ballast..... Now a HARNESS issue everyone has been talking about... .that is XD provides a Relay harness which when activated draws power from the Battery and not from the OEM harness... however, just so you guys know that is completely unnecessary (as CAPIRATO will support me I am sure). The total draw from the ballast and bulbs is actually 42Watts which is well below the 55w bulbs everyone has in the vehicle so there will be no worries of melting anything here (I checked and that is EXACTLY how much the Philips ballasts draw as per Sylvania). ...
COLOR... Admittidely I have made a MISTAKE... (both concisously and otherwise after some wavering) of installing an 8000k kit.... BIGGER IS NOT ALWAYS BETTER... I would probably opt for somehting like a 5000k kit maximum... you WILL LOOSE over 600 lumnes going from 4300 (or rather 4250k ) to 8000k (and a little less for 6000k) even with the highest quality bulb... stick to the 4000s ranges... its BETTER!!! though some might prefer the cold Ice blue look... but the lumens are just not there...
So learn from my mistakes..... what kit you get does make a difference but no so much so as the color/quality of the bulb... many kits sold these days even for $!60 have a decent electronic ballast (if it has ignitesr inside) that will do quite fine ... just make sure you know a bit about what you are getting... AGAIN, I would love to buy from XD but I think the prices are yet a ted bit too high (though 4300k kits are probably worht it). I think if the we got to very low 300s on ALL Colors EVERYONE will buy the kits![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Peace
Peace
#101
Peace
Peace
#102
That is not true. The starting wattage has nothing to do with it since its the VOLTAGE not the wattage. Also its the STARTER that is providing the initial voltage spike not the vehicle. Again that is why the components are there, you cannot draw more voltage that is already provided on the line. Imagine a using a 9v bulb on a 3volt battery...
#103
![Wink](https://www.clublexus.com/forums/images/icons/icon12.gif)
robinzon, Starter is not the one that gives you voltage!
Starter takes voltage fro battery and start your car!!!
Alternator is charging the battery and alternator the one that giving you Voltage!
#104
I am talking about HID STARTER ie IGNITER (NOT the car's Starter)... here is a quarter go buy a CLUE
#105
