VAIS Tech
I'm wondering if anyone has encountered this problem after installing the VAIS Tech XM. The unit works great as has tech support. That said, there is single problem they can not seem to fix. When the music changes there is supposed to be a pop-up screen identifying the title and artist...this will not work. Have followed all the directions in the manual and from tech support with no luck.
If you had this problem what is the fix? Thanks.
i have an 04 and the info at VAIS looks like there should be a MD selection to make the display pop up. Is that corect? My 04 doesn NOT have the MD option
Originally Posted by rkrzyston
I have an 04 and the info at VAIS looks like there should be a MD selection to make the display pop up. Is that correct? My 04 does NOT have the MD option
I use Track 1 for Sirius and Track 2 for DVD/TV players.
~ Cap
StickyIcky
01-24-08 05:58 AM
