Prado Lights Finally done
Old 06-06-05, 04:40 PM
angelslex
angelslex's Avatar
Default Prado Lights Finally done
Finally after all the problems I had with Bulbs and Sockets ,Ken from Japanparts.com was able to send me the parts to finally Install the lights. Thanks to Capirato and the rest of the guys that PM about this Mod.
Old 06-06-05, 04:43 PM
angelslex
angelslex's Avatar
Default Prado lights
2 pic wiring for the passenger side I was able to find to new pins with wires from other plugs i had laying around
Old 06-06-05, 04:45 PM
angelslex
angelslex's Avatar
3 pic new pins on the GX plug
Old 06-06-05, 04:47 PM
angelslex
angelslex's Avatar
4 pic remove tape and cut OEM wires to connect new wires.
Old 06-06-05, 04:48 PM
angelslex
angelslex's Avatar
5 pic testing lighting Brake lights and blinkers.
Old 06-06-05, 04:50 PM
angelslex
angelslex's Avatar
6 pic Tail lights and blinkers
Old 06-06-05, 04:59 PM
angelslex
angelslex's Avatar
7 pic made the ones on the bottom parking lights
Old 06-06-05, 05:03 PM
angelslex
angelslex's Avatar
Has anyone use a 921(RED) LED bulbs ? Do I need a resistor ? Im using a regular 922 red right now but looks a little pink. seen the lense is clear I ned something bright red like the ones on the 3rd brake light..
Old 06-06-05, 10:39 PM
Capirato
Capirato's Avatar
Hi Angel.....
CONGRATULATIONS
I opted to make the bottom light work in conjunction with the middle light which is the Turn Signals.
~ Cap
Old 06-10-05, 02:39 PM
angelslex
angelslex's Avatar
Thanks for all your help. I order the 921 Red LEDs from superbrightleds or something like that.
Old 02-23-06, 06:49 AM
antonio98
antonio98's Avatar
Question
Angelslex-
I can see the wires that need to be moved, but I'm having trouble pulling them out.
Can you tell me how to pull the wire out from one slot and move it to the other?
Is there a way to release the wire, or do i just have to pull harder?
Thanks for your help.
Antonio.
Old 02-24-06, 11:44 AM
angelslex
angelslex's Avatar
Just pull a little harder there is something holding the harness . like a wire tie .
Old 03-12-07, 06:37 AM
CaMsGS3
CaMsGS3's Avatar
guys just wondering since this thread is about a yr. old, do they make these lights plug and play now, + where can you purchase these
thanks
Old 03-15-07, 01:34 AM
Slavic
Slavic's Avatar
Hello, i'm from Europe and there are a lot of prados here, i like more the original Lexus GX Lights, don't tgink that prado lights looks better.
Old 03-15-07, 08:48 AM
The G Man
The G Man's Avatar
Kind of looks like the Sequoia's tail lights but narrower.
Quick Reply: Prado Lights Finally done
