View Poll Results: What kind of gas are you using these days?
Premium
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
93
51.96%
Regular
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
86
48.04%
Voters: 179. You may not vote on this poll
What kind of gas? Premium or regular? (merged GX gas threads)
#271
#273
Agreed, I was kind of looking for someone using regular to see if they had any issues, not thinking of switching anytime soon but I do live in the south where hurricanes and tropical storms are common and sometimes premium is hard to come by after those kind of storm events. Guess I could just keep a bottle of octane boost in the back.
#275
Since our '08 seems to run perfectly on regular, I doubt I will ever try premium. Would it run better on premium, or get better mileage? Don't know & don't care.
#277
I have been looking into this briefly.
I almost consider starting a new forum not on quality of gas but the variability of gas stations. There does appear to be a difference from a cheaper station (like Wawa for the east coasters on here) as opposed to a Shell or an ExxonMobile.
Before I did my research I noticed with:
Regular the GX got 17.6MPG average
Premium in the GX I saw a dramatic 0.1 MPG improvement totalling 17.7 MPG AVG
After my research, I learned particularly when these engines get a little age under them, it is essential to run fuel injector cleaner in the tank every so often. Specifically I chose chevron techron concentrate as discussed in another post.
(https://www.clublexus.com/forums/gx-...injectors.html)
Throw this in either Regular or Premium and you will see a more noticable change. The GX says shes doing 18.6 MPG AVG today with just regular in and after a few fuel injector cleaner bottles run through the system. I recommend keeping up with this!!!
CHEERS
CHEERS
#278
Thanks TopGear for the reco. I never thought of using Chevron Techron in the GX as I never seen that recommendation. My truck is an 08 and has 70K on the dash. I would need to do some research.
As for gas, I use Premium on an regular basis. The manual does mention that you can use Regular temporarily but you have to go back to premium. I think premium will have a better impact on the GX engine longevity.
I stay away from BP gas, I tried it twice and makes the car feel so heavy and sluggish, I only use Exxon.
Thanks again
-rbx10
Thanks again
-rbx10
#279
#280
Just curious if everyone uses premium fuel or like me just 87 octane. When gas hit over $ 4.00 a few years ago I started using 87 and never went back. At the time did some milage comparisons and didn't notice any difference. I have pulled a 6000 lb boat and the engine never complained. I'm sure there are some use cases for the premium fuel but not for the driving my wife does.
#281
Going on 9 yrs and 90k miles, I never noticed a difference, so I only use 87 and I too pulled a heavy load with regularity. Depending on the year, it's more of an emissions thing to use premium.
#282
This thread was combined/moved with another one at least once, hope it helps.
https://www.clublexus.com/forums/gx-...s-regular.html
#283
2005 and older 2UZ-FE engines called for 87 or higher octane and 2006+ called for 91 or higher due to newer emmissions requirements/turning (ULEVII, SFTP). My owner's manual calls for 87 octane. All model year engines will run on 87 without issue, but you may notice a slight decrease in performance (output/MPG's). If you have not noticed a difference in gas mileage or performance or engine knocking stick with what you are doing.
#285
When I bought my 2004 with about 104K, I assumed since it was a Lexus it needed Premium, so for the last 20 months, I have been putting in premium.
Well, for no reason, I'm comparing gas mileage and it says that I should be using Regular. So, should I go to 91 for a few tanks, then 87 or is it OK to go straight to 87, or fill up now when I have 1/2 93 in there, and then switch, or could end up causing problems with timing, etc. since it has been running premium the last 2 years or so? I don't know what the previous owner was running, it was a 1-owner vehicle before I bought it.
At about 120K, the car runs solid, smooth, no oil drips, etc.
Saving $0.30 a gallon, $6 a tank a tank or so. I actually read that 87 octane will give you the best mileage, 93 will give you the best performance...come on, its an SUV, I'm more worried about gas mileage.
Thoughts?
Thoughts?
