View Poll Results: What kind of gas are you using these days?
Premium
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
93
51.96%
Regular
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
86
48.04%
Voters: 179. You may not vote on this poll
What kind of gas? Premium or regular? (merged GX gas threads)
#91
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
Originally Posted by robert55
Hello, I would like to query GX470 owners to determine what level octane you are using in your car. The manual states that 91 is the preferred octane level, but you can use 87 if necessary. I know of a few people who use 87, but the manual leads you to believe that the manufacturer prefers 91. What are you using? Do you see a performance difference between both octane levels? Will I be causing potential damage to my car if I use 87? Our dealer stated that you can use 87 in the GX470. Thanks for the opinions!!
There was a thread discussed a while back in this forum, and it seem pretty much a personal decision to which octane people use. There is not an average "better result" from using the higher octane. Some found that the performance got snappier, but the overall fuel mileage went down (that sounds about right doesn't it
#92
Originally Posted by ADVocate
You probably have the 2005 model that had the horsepower boost w/ VVT. I think the 2005 might require the higher octane for the better overall perfromance, due to the valve design. The previous models did not mention a preference for the 91 octane. I am not sure what the 2006 has put in their manuals, since Lexus also did a design change that dropped the horsepower again.
#93
From 2004 owner's manual:
GAS STATION INFORMATION
Fuel selection:
Select Octane Rating 87 (Research Octane Number 91) or
higher. For improved vehicle performance, the use of
premium unleaded gasoline with an Octane Rating of 91
(Research Octane Number 96) or higher is recommended.
From 2006 owner's manual:
Fuel selection:
Select premium unleaded gasoline with an Octane Rating
of 91 (Research Octane Number 96) or higher for optimum
engine performance. However, if such premium type
cannot be obtained, you may temporarily use unleaded
gasoline with an Octane Rating as low as 87 (Research
Octane Number 91).
So that's our answer. It looks like the engine with VVT-i does prefer premium, though I wish they used less vague language. Words like "temporarily" don't make much sense in this scenario IMO. You can either run it on 87 or not...
Fuel selection:
Fuel selection:
Octane Number 91).
#94
My conclusion is, the lowest octane for the older engines and the middle choice for the newer engines. With the preference of going up one notch on either one of the engines for best performance.
~ Cap
#95
Fuel selection:
Fuel selection:
Octane Number 91).
Fuel selection:
Fuel selection:
Octane Number 91).
I wonder why Lexus change the wording on the 06 manual?
#98
This topic has been "beat to death" but one more time might not kill it so here is the summary...
87 Octane will provide you the best fuel ECONOMY
91 (or higher) Octane will provide you better PERFORMANCE.
This trunk is DESIGNED to run on 87. Running 87 does NOT harm the engine in ANY way. Reports of sulfur smell can ONLY be related to the mfg type of fuel burned, not the Octane (i.e. wally's cheapo gas - 87 octane may smell but 87 Octane from Exxon, BP, and Smart Mart, Petro Express, etc and even BJ's does not produce any smell in my GX470). Using 87 Octane I acchieved 23MPG on a 5 hour trip. Using 93 Octane the best I could achieve (on the exact same trip but different day with similar temps) was 19.7.
Mine is an '04 and does not have the VVT so performance may be different in the trucks witht he variable value timing .
#99
I was part of that group that always filled it up with Super (highest octane), when gas prices went up and I was seeing $60+ tank refills with Super, I tried Regular (lowest octane) for the heck of it.
To tell you the truth, I can't tell the difference..... maybe I am getting worse gas mileage, but nothing else has changed. Maybe it's all a marketing scam!
#100
I traded in an 05 GX and picked up a new 06 GX today. I noticed that the 06 has a decal on the inside of the fuel door which says to use premium unleaded. The 05 never had the decal.
#102
91 (or higher) Octane will provide you better PERFORMANCE.\
Thanks.
#103
I know many folks reported better gas mileage when using Octane 87 vs Octane 91 gas.
I have a 2005 GX with about 2,200 miles. So far, I got around 18.5 miles/gallon with Octane 91 (premium).
However, when I switched to Octane 87 (regular), gas mileage dropped to 17 miles/gallon.
Any reasons why I got difference results?
#104
With 91, you get more compression with every engine stroke, hence, more horsepower and torque with same amount of gas injected. If driving style remains the same with 87 and 91. Using 91 should give you better gas mileage. The poeple who reported better gas mileage with the 87 are probably driving more aggressive while using 91.
