2004 GX470 Nav overide
Old 12-03-05 | 10:37 AM
julieh's Avatar
julieh
Question 2004 GX470 Nav overide
In reading these posts I have come to the conclusion that there are no fixes for my 'older' system for putting in XM radio or overriding Nav system to allow setting destinations while moving. Is this correct?
Also I'm sure the salesman mumbled yeah when I asked about this car being bluetooth phone ready but how do I find out for sure before buying a bluetooth phone?
Old 12-03-05 | 01:43 PM
BobsGX's Avatar
BobsGX
I don't believe any of the 04 GX's are bluetooth capable and only the Mark Levinson/Navigation equipped 05-06 GX's are able to use a bluetooth phone.
Old 12-03-05 | 02:54 PM
lonewolf69's Avatar
lonewolf69
Hi Julieh,
No the GX470 04' is NOT bluetooth capable, this was a new feature for the '05 model and carried over to the 06' model. As for the Nav overide "fix", it really is an easter egg, or back door for the Lexus Service Techs to change some of the settings of the GX. So far, only the 05' easter egg/backdoor has been posted.
That said, I'm 200% sure that such an easter egg is available for the 04' model, just hope some kind soul will know about and post it here on the forum....
Good luck...!
Old 12-04-05 | 07:41 AM
GS450h FTL's Avatar
GS450h FTL
Default not a fix but a good work around
Have you tried--
Press Menu
Press Volume
Press the Top Left Corner
Press the Bottom Left Corner (there is nothing there)
A new menu screen will come up
Press and hold Override for 5 seconds or until you hear a beep.
This allows my passenger to put in addresses while moving in my '04
Old 12-04-05 | 08:34 PM
e71260's Avatar
e71260
Hello There,
When I clicked on Volume and click Top Left and Bottom Left, nothing happens. Do I need to be driving in order to do this? thanks for the help.
Old 12-04-05 | 11:48 PM
Capirato's Avatar
Capirato
Default Override
With ignition key on.....
Press on "I agree"
Press on "Menu"
Press on "DVD"
Press on upper left corner of screen
Press on lower left corner of screen
Press on lower right corner of screen
Press on "Override" and hold until a beep is heard
Press "Back"
Press "MAP / Voice"
That's it !!!
~ Cap
Old 12-05-05 | 06:25 AM
25cliffy's Avatar
25cliffy
You're the man Cap!
Old 12-05-05 | 07:51 AM
lonewolf69's Avatar
lonewolf69
Great news! I was told that this "fix" was only for the 05' model and that it wouldn't work for the 04' model...
Old 12-21-05 | 07:36 PM
zezspest's Avatar
zezspest
Using Cap's post from above , I am able to overide the Nav system on my 04 GX. Yesterday after doing this, my passenger started inputting an address when up popped another screen which I had never seen. It contained a bunch of NAV system checks and the strangest one was a button allowing me to turn on my back-up camera while driving forward. What a sight it was driving 70MPH and looking at the road behind you! In addition, the only way the diagnostic screen would turn off was to re-start the engine. Now, I cannot duplicate it.
Has anyone else experienced this? Does anyone know the exact sequence?
Old 12-22-05 | 12:17 AM
robinzon's Avatar
robinzon
On the `04 models you go to MENU then DVD then
press in the Upper Left Corner, Lower Left Corner, Upper Left Corner, Lower Left corner, Lower Right Corner..
that is all there is to it
Old 12-22-05 | 09:13 AM
Tony's Avatar
Tony
Default This works for all 04 Navs from Toyota
I did this to my wife's Toyota Sieena minivan and my friends 4 runner and it worked.
Old 12-22-05 | 09:51 AM
cab2u's Avatar
cab2u
Little confused. I tried this on my 04 but it did not work. When you press menu, do you press the dvd button on the screen on the upper right? It is not lit up when I go to menu?
Old 12-22-05 | 11:43 AM
robinzon's Avatar
robinzon
You have to be fully stopped and parked in order to press the DVD button.
Old 12-26-05 | 06:00 AM
Saveli's Avatar
Saveli
This doesn’t working on 2004 Lexus GX or LX, because “override” function not available on service menu. Only after 2005 years.
Old 12-26-05 | 08:41 AM
GS450h FTL's Avatar
GS450h FTL
Default Actually it does
I have a 2004 and it does work ---
Quick Reply: 2004 GX470 Nav overide
