22's on GX
Originally Posted by peterGX470
The Stock over all diameter is 30.56" (265/65/17) http://www.1010tires.com/TireSizeCal...?action=submit
With 26" wheel consider the tire size option is 305/35/26 your over all diameter is 34.4" which is about 4" bigger! You are over 11% !
With 305/30/26 which is 33.2", a 8% bigger! There no other size in between on the market unless you can get it special made in 295/20/26 which is 30.65" which i doubt it!
If your GX wheel are not +/- 3% you are in danger of brake failure!! Not to mention your speedometer is off, way off!!
So! My question is HOW do you put 26" on your GX and only gain .1" or 1" overall diameter????
Maybe with out the tire...j/k
Let see some pictures??
The difference between what I have now to size i am going to is what I stated...this was confirmed by both Foose and discount tire....I had it double checked before I ordered 10k worth of wheels and tires that would not be refundable. Everyone said I would have brake issues on the 24s, which I have not...I pulled a flatbed trailer with a car on it a few times a week and still stop as if it were stock...I had 26s on my EXT and never had any braking issues either...Im not saying it cant happen...just hasnt happened to me
kgbagent1
GX - 2nd Gen (2010-2023)
15
12-30-16 10:16 AM
