fogs only
Old 03-13-06, 07:24 PM
wilderGX47
wilderGX47's Avatar
Default fogs only
fogs on without headlamps
fogs w/o headlamps
Old 03-13-06, 07:44 PM
lepoch
lepoch's Avatar
how???
ELEX470
ELEX470's Avatar
Default looks nice
How did you do it?
Old 03-13-06, 08:00 PM
wilderGX47
wilderGX47's Avatar
Default this how
main realy for the fog is tirggerd to close the fog circuit when power is applied to the healamp lowbeam circuit. I simply open the harnes on the driver side running to fuse block, probed to the right wire, cut, and supplied power fromt the parklight circuit
Voia La
Old 03-13-06, 08:14 PM
ELEX470
ELEX470's Avatar
Default diagram?
can you make a smoll diagramm with wire colors?
Old 03-14-06, 05:36 AM
wilderGX47
wilderGX47's Avatar
Default diagram
yeah, let me get some things together... keep checking i'll have it posted probaly in the lighting section
Old 03-14-06, 09:18 AM
lexbuddy
lexbuddy's Avatar
Hello,
I believe the wire you are referring to is the Red-Yellow wire going to the Front Fog Relay in the engine fuse box. Attached is the lexus wiring diagram.
File Type: pdf
Old 03-14-06, 09:30 AM
ELEX470
ELEX470's Avatar
Default lexbuddy
Can you please explain witch wire needs to be cut and where?
Thank you
Originally Posted by lexbuddy
Hello,
Old 03-14-06, 10:58 AM
Capirato
Capirato's Avatar
Wilder.....
Am I correct to assume that you don't now have, parking light only ??
~ Cap
Old 03-14-06, 12:30 PM
Capirato
Capirato's Avatar
Default Fog Lights anytime at will
Wilder.....
These instructions are for the GS, but should be similar to the GX. This modification will allow you to turn on the Fog Lights anytime at will.
http://lexusmodz.netfirms.com/GS_DIY/fogmod/
~ Cap
Old 03-14-06, 01:41 PM
wilderGX47
wilderGX47's Avatar
Default Yes
i do have park lights only if need, the fog lights opperate as the did before except i can turn them on with the park lights.
Yes it is the red wire with a yellow tracer. THOUGH! there are 2 red/yellow wires running to the fuse block.
#2 terminal for the fog relay is what you need. pull the realy, probe #2, then prob either red/yellow wire. When you find the right one, cut it in half. Side leading back into cab, tape and seal, put away. The other end leading back into the block, connect a wire to it, then i taped in the power side of the small peanut bulb by the orange drl bulb.
Old 03-14-06, 01:52 PM
ELEX470
ELEX470's Avatar
1) what is "cab"?
2) "connect a wire to it" what is it? connect to what?
Thanks
Old 03-14-06, 08:00 PM
wilderGX47
wilderGX47's Avatar
Default um
cab., short for cabin, inside vehicle, interior space, drivers seat...........
connect "splice"(better?) a lead of wire the other end of the cut wire, with a butt-connector, scotch lock, solder and heat srink tube, twist the ends and tape it, what ever you prefer..
then splice the lead wire into your chosen power source
you should have some knowledge of automotive electronics and wiring before trying this. you cut the wrong wire, splice to the wrong power source..... have fun explaining to the dealer what your doing.
Old 03-15-06, 07:03 AM
ELEX470
ELEX470's Avatar
Default to wilderGX47
Can you please draw a diagram to see how to do it?
Thanks
boxcarfan
GS - 1st Gen (1993-1997)
19
08-23-11 08:44 PM
abounly
SC- 1st Gen (1992-2000)
03-17-10 08:16 PM
LouieV
20
12-22-08 09:23 PM
17gs400
09-08-07 08:24 PM
maniax
04-06-06 07:26 PM
Quick Reply: fogs only
