Ethanol Gas ???
so I get this $20 gas card for the ethanol gas .. do I use it or throw it away ..
I'm not sure I want to put that gas brand in my Lexus will it damage the GX470??
any thoughts ??
Tipler
any thoughts ??
Tipler
Is it for ethanol (E85) or for gas with ethanol?
As of early May, the additive on gasoline is changing from MTBE to ethanol. Most cars can run with up to a 10% ethanol/90% gasoline blend. Check the manual for the exact number.
E85 (85% ethanol/15% gasoline) is another story. Few cars can run on that from the factory, (2006 C320, Dodge Ram 1500 4.7, etc.) - NOT the GX.
Originally Posted by Tipler
it says for (10% or 85% blend )
I'll have to check the manual ...
thanks
thanks
FROM THE MANUAL
Cleaner burning gasoline
Cleaner burning gasoline, including reformulated gasoline that contains oxygenates such as ethanol or MTBE is available in many areas. Lexus recommends the use of cleaner burning gasoline and
appropriately blended reformulated gasoline. These types of gasoline provide excellent vehicle performance, reduce vehicle emissions, and improve air quality.
Oxygenates in gasoline
Lexus allows the use of oxygenate blended gasoline where the oxygenate content is up to 10% ethanol or 15% MTBE. If you use gasohol in your Lexus, be sure that it has an octane rating no lower than 87. Lexus does not recommend the use of gasoline containing methanol.
Kbach
GX - 1st Gen (2003-2009)
388
11-30-20 03:05 AM
beachfront
03-10-15 09:31 AM
