What do you guys think of this??
Was browsing Ebay came across this performace upgrade chip specifically designed for GX... any thoughts?
http://cgi.ebay.ca/ULTIMATE-PERFORMA...QQcmdZViewItem
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
Regards
Darrell
contacted the seller of this item n asked him how does this thing worked and this is what he said
"Hello,
The chip is installed into the Intake Air Temperature sensor of your vehicle. It modifies the sensor, telling it to send the message that you are receiving optimal air temperature into your air box. This message is relayed to the ECU, which in turn tells your engine that conditions are optimal and it can therefore perform at optimal conditions. This allows your engine to perform better, which results in increased horsepower and torque. This process does not harm your engine in any way.
What we are selling you is the chip that is installed onto the IAT sensor. Along with the chip you'll receive detailed instructions that will tell you exactly how to find your IAT sensor and how to install the chip. The chip plugs right into the sensor so you don't have to worry about cutting wires or soldering. It's very simple with the instructions we'll send you. If you have any more questions feel free to ask!
AccelRacing"
does it make any sense or no??
"Hello,
AccelRacing"
So this chip tells the computer that you are receiving optimal air temperature even when you are not. Sounds like this chip might decrease fuel efficiency and void the warrenty.
What it looks like this thing does is overrides, or circumvents, the chip that Lexus designed for hopefully a good reason. I don't know enough about either system to know whether that will adversely affect performance, milage, emmissions, engine life or all of the above. What you are doing is having the sensor "lie" to the ECU about conditions - kind of like having your brain tell your body it isn't really cold outside so go take a walk in zero degrees in shorts and a tee shirt. I don't see where any long term good can come of this.
yeah.. well my car is out of warranty now.. so warranty is not a concern... but i just don't know whether it will do any bad to the engine.
i mean there r lot of after market chips that people put .. which overrides the manufacture systems.. but is not neccessarily bad for the car... for example.. speed breaker overide chip.. which stops the car at 112 mph for nhsta requirement can be overriden..
i just think it mite decrease the fuel efficiency... but then there r lot of things which go between the air pressure to actually improove it.. like tornado for example.. i have tornado installed on my landcruiser and it does save about 50 km on a gas tank.. which is not whole lot but it helps
![Red face](https://www.clublexus.com/forums/images/icons/icon11.gif)
I got suckered a long time ago (before CL
) regarding an "air intake chip". It's basically a cheapy 10cent 330 ohm resistor that you plug in the maf sensor that bypasses this and that.
I didn't want to bother with it and never installed it and everytime I see these "intake chip" to save gas, increase torque, ALL FOR LESS THAN $10 WITHOUT AFFECTING WARRANTY, I just run the other way.
I think people are getting a little tricky and started to put these resistors in a box to look sophisicated.
I'll see if I can scan the instructions if I still have it.
Well you can try it if you like. At least he's not charging $10-$40 like back then with a $5 shipping charge where they just .37c stamp..........but I wouldn't waste my $
Originally Posted by davidc1
How does being out of warranty give you any comfort? If this chip ends up messing up your engine, it will cost you dearly.
Hello,
Keep your $20 and avoid spending for a new engine once yours overheats.... Performance chips that you are talking about are modified ECUs with different fuel curve and timings... they cost above $300 and usually involve sending your ECU for reprogramming... furthermore, there are few mods to Lexus chips. The most efficient chip mods apply to Turbocharged vehicles and also involve decreseasing the diamter of vacuum hoses that effectively tells the ECU that boost pressure is less then what it really is... look for Wolf chips ,etc... not this crap.
thanks
thanks
