going to the dealer - wheel play
Old 06-01-06 | 11:14 AM
stl2chi's Avatar
stl2chi
Default going to the dealer - wheel play
Hey Forum
Got a few questions.
While driving at highway speeds this weekend, I noticed steering wheel play/ vibration when applying the brakes... My first thought is brakes..... However, I only 18K on my 2005. Afterwards, I starting noticing vibrations at 60- 70 mph speeds... just not as pronounced as when applying brakes.
Can it be anything else?
Are there anything specific that I should tell the dealer to address / check?
Any TSBs?
Isn't 18k a little early for brake issues......
Concerned...
STL2CHI
Old 06-01-06 | 11:44 AM
caha14's Avatar
caha14
Default Read away...
This should do the trick: http://alldata.com/tsb/Lexus/1122534...0000_ST002-05/
You may also have warped rotors, but the fact that you get vibration without applying the brakes leads me to believe that your dealer should take a look at this first.
Old 06-01-06 | 10:04 PM
sayadil's Avatar
sayadil
Originally Posted by stl2chi
Hey Forum
Any TSBs?
Concerned...
STL2CHI
STEERING VIBRATION/DRONE NOISE TSB is what u need. as mentioned by Caha.. u mite have warped Rotors as well (Common problem with GX factory Rotors) would recommended switching to BREMBO Cross Drilled, they run only around 120 on ebay for a set.. and u will not have a problem again.
cataphora
Suspension and Brakes
04-17-18 08:09 AM
mi430
06-29-13 11:35 AM
troz350
06-15-07 04:26 PM
rsxtc
08-19-05 10:58 AM
pklibak
Maintenance
08-10-04 03:07 PM
Quick Reply: going to the dealer - wheel play
