Front Suspension Issues?
I did a search on this already but didnt really find anything...I wanted to know if anyone else has had this problem.
I have an 05, non KDSS GX. I have had it for exactly a year now,15k in milage. I have not taken my rig off road at all (some fire road use but nothing crazy). As well, i have not hit any large pot holes or jared the front suspension in any way.
Recently, I have noticed that if im turning the wheel all the way to the left while moving forward (picture a 3 point turn or something of the like), I get a metalic groan from the left front suspension. I cant really pin point it but it's enoug to actually feel inside the cabin. As well, if I were to hit any sort of bump or incline while the wheel is turned? its even worse. Im not sure im explaining it right but I know that it is not normal. Im due for my 15k oil/tire rotation deal so i will have them check it out, im still under waranty so im sure they will fix it. I just wanted to see if anyone else has experienced anything similar.
FYI, im not talking about that noise you get from the power steering when you turn the wheel all the way..this is much more, um, metalic crunchy sounding.
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
Is it when the wheel is turned all the way over to the lock? If so, I bet it's the steering bumpstops...happens on many toyota trucks. The remedy is to put some grease on the bumpstop. Some vehicles come w/ a plastic cover on this bolt (which falls off over time), so you get metal on metal rubbing at full lock. When you go over a bump, it rubs even more, making a louder sound.
Yeah, the sound is when the wheel is completely turned but it only occurs on the left side. Im pretty sure i can re-create the sound on comand...luckily. At least y'all agree that is friggin strange. Thanks again for all the help.
T.
T.
Threxx
Suspension
06-05-06 01:14 AM
