coastaltech and Viastech...
Old 10-15-06 | 11:43 PM
nate579's Avatar
nate579
Default coastaltech and Viastech...
Who here has installed them both, I have the lockpick ultimate on the way and I have Viastech SLI Ipod adapter. Has anyone installed both if it can be done at all. Let me know, because if push come to shove I can sell the SLI and wait for coastaltech to get one up and running from what I have been hearing.
Old 10-17-06 | 05:54 PM
rklages's Avatar
rklages
Do a search someone posted about it and had them both working and could choose which one pushed the I agree button as both them did it.
Old 10-17-06 | 08:13 PM
nate579's Avatar
nate579
Yea did that but wasn't as fruitful as I would have liked. Will try again.
Old 10-19-06 | 10:18 AM
Lou19's Avatar
Lou19
Part of an old post of mine:
I have installed the Ultimate Lockpick and continue to use the Vais SLI Ipod Adapter. Except for a need to separate the audio feeds with an isolator or switch, all is well. It seems they both send audio into the same input, so the Lockpick wins every time. There is a note about this, in the instructions, so I am not surprised.
I disabled the Vais "I agree" feature so the Coastal unit would do it. The Lockpick fires the "I agree" faster and does not seem to be confused by immediately going into reverse after start up. The destination and Bluetooth overrides have worked flawlessly.
Hope this is fruitier.
Lou
OIF VET
42nd "Convicts"
Never Forget
Old 10-21-06 | 09:35 PM
nate579's Avatar
nate579
Lou
OIF VET
42nd "Convicts"
Never Forget
Thanks Lou, I did just that and its working so far. My wife loves the fact she can watch DVD upfront now, while I am driving. Most of the movies she watch is chick flix. So I am totally focused on driving. Ipod is working flawlessly. Thanks for the advance.
Old 10-21-06 | 11:33 PM
DM.ru's Avatar
DM.ru
Hey guys, can you tell me more about installation of lockpick ultimate? Does it including wiring, etc? Just want to get more details before I buy it.
Thanks
Old 10-22-06 | 11:09 AM
PuPpYpWr's Avatar
PuPpYpWr
lock pick comes with everything you need to install. allyou have to do is once you have gotten into the back of the monitor and radio is plug in the lock pick and replug in your factory plug
Old 08-25-07 | 01:23 PM
Options2k's Avatar
Options2k
Lou
OIF VET
42nd "Convicts"
Never Forget
Thanks Lou. I am planning to do the same on my 2006 GX. Based on what I read here, lockpick is needed to use the NAV and BT while the vehicle is in motion AND the VAISTECH IPOD interface is needed to connect an IPOD and choose the songs through the NAV screen interactively. Is my understanding correct? Also, which models of both I should order.
Thanks once again.
Old 08-30-07 | 01:46 PM
Options2k's Avatar
Options2k
Thanks once again.
Can some help with the above comparison.
Old 09-09-07 | 03:56 PM
jsa_ny's Avatar
jsa_ny
You're correct in your assumption. I went through this installation today, and you can read my results at the VAIS thread below. Note that I did this in a 2007 Prius, but the same should apply to Lexus configurations.
Good luck.
http://www.vaistech.com/forums/showthread.php?t=606
Old 09-16-07 | 06:47 PM
rklages's Avatar
rklages
Yes it will work - I have a 2006 - Viastech SLI with Aux input and IPOD - it can also do the I Agree Button, slightly slower than the Lockpick, so it will never normally notice it and you can disable it (actually you have to enable it, it is off by default which is what you want). The Lockpick Ultimate will do the I agree, unlock the nav and bluetooth and will also provide an audio and video input into the front screen. Both work differently - Lockpick you can't really customize settings or turn things on or off - all the features are just on. It will use the DVD input for the aux audio/video input. The Viastech uses the MD input on the factory system for the inputs, so everything will work fine all together.
Rob
Old 09-17-07 | 12:31 AM
Options2k's Avatar
Options2k
Thumbs up
Rob
Great and thanks. A few more questions:
What version is the NAV software in your truck? Does the lockpick work with v6.1? Are both of the devices installed behind the NAV screen in the dash or the lockpic goes to the NAV DVD under the passenger seat?
I may ask you a few more questions later when I actually install the devices.
Thanks.
Old 09-02-08 | 08:31 AM
looknow12's Avatar
looknow12
Default Need AUX Input only
Will the any of these products provide an AUX input for a 2004 GX470?
sarmyth
12-16-16 06:13 AM
Thooktrash
01-19-12 09:24 AM
tbartman
RX - 3rd Gen (2010-2015)
02-17-11 09:00 AM
CashOverAs
04-23-09 08:45 AM
lok888
07-25-07 12:08 PM
