Need Help with the Mile left gauge Please
I think I also read that the altimeter uses the air pressure inside the cabin, which of course would make it way off with the windows closed. It does know when it is up in the mountains (it gave much higher numbers in the Catskills, for instance), but let's say that I wouldn't want to fly a plane using it .
Jasp - those milage numbers do sound low for I95, although if some of that is passing Philly during rush hour that is another story. You might want to do the hassle of recording milage vs actual gallons at fill up and get a true number.
Some of the good milage I have gotten has even been during ascent, so I doubt that is the problem.
I bought the RX partially to have a better milage vehicle, but that has been a bust. The RX averages maybe a couple of miles per gallon better (based on its trip computer). From what I could tell the hybrid RX400H only does one or two mpg better than the regular RX350, so that is no panacea either.
FYI, related to comments on Lexus altimeter works "just" on barometric pressure...
ALL altimeters work on barometric pressure. Just the more precise ones, are much more expensive. Also, to be accurate (i.e. for airplanes) they need to be calibrated each time (or at least once a day) to a known altitude.
Now a days with the GPS satellites, if you get grab enough satellites you can get an elevation, but again the accuracy depends on the number of sats.
Not sure whether the Lexus alti works on inside or outside air, but it really is a myth that car cabins can be "pressurized" like an airplane cabin. They can't, even with windows up, and A/C on re-circ, there is still an outside air flow.
This should not be confused with the pressure you may feel when you crack a window at high speed, that pressure differential is due to the venturi effect of the outside airflow around the car, causing a pressure differential.
So what you are saying is that each time you want to use the altimeter, you need to calibrate it to the current barometric pressure by setting it to a known altitute.
The new EPA standard for calculating MPG has nothing to do with lowering actual gas mileage of the car, it just changes the testing criteria for calculating the MPG you see on the window sticker to reflect a more realistic number during real world driving conditions. Like I mentioned earlier, a new car getting 12 MPG in the winter is not totally unreasonable if you drive all city and make many short trips.
CV
If you've every flown in a small plane and could see the cockpit, that's one of the pilot checkoffs. Every airport (large or small) has a known and published altitude. Pilot dials in the known altitude while sitting on the ground. Then they are good to go.
I'm not familar with the latest airplane technology, perhaps now they use radar or something along with topo maps. But I'm sure there is still an altimeter in there.
I can't comment on it's usefulness, but it sure is interesting to know how high some of those mountains in PA are when driving around.
Obviously, the easiest way to set it is to be at sea level (at a beach) and set it to 0. Otherwise, check some map data to find the altitude of your house, and just set it from there whenever you want.
Here is a stupid question. Let just say I calibrate the zero at sea level, what happens if I travel long distance to another region where the base barometric pressure is diff. ie: if I travel from a low pressure zone to a high pressure zone. The gauge will no longer be accurate, correct?
Sames applies if you stay in the same place, and a front comes thru (or leaves).
I haven't looked into how much variation weather can affect vs the change due to actual altitude. So I don't know if significant.
However, in a car, what do you do with the altitude information anway, not much, just interesting. And if it's 500 feet off, does that have any significant impact to anything we are doing. Not really, in my opinion.
I consider the altitude readout is just a "freebie" as they had to include a air presssure sensor as part of the engine control package. Interesting to glance at, occasionally.
Perhaps you can simply reset the computer ....
I bought a new GX 470 in Aug and right now I only have around 5800 miles on it. What I noticed was when I filled my tank yesterday my gauge with the miles left (up with the temp, ALT, Degrees, so on) is not working. What happen is I filled the tank and now it tells me miles left was 210. Now I know this is very wrong on a full tank of gas (maybe a bit overfilled). I have already tried undoing the gas tank cap and putting it back on and restarting the truck but nothing works. It's counting down fine but it's just not correct. Does anyone know what this could be or how to fix it without a trip to the shop?
Sami
Sami
As for the Altimeter, it is the barometric type. You CANNOT set it accurately. Nor, will it ever give you an accurate reading. It relies on Atmospheric pressure that not only changes with Altitude, but weather as well. So if you set it up at sea level, and you have a storm on your journey upwards, it will rarely give you an accurate reading at all. But, it is a good "guess-timate".
