factory lights
GX, no relay, plug and play unit. I believe I got the 5k unit-the closest to white color vs the purple items. I actually noticed them last night as I commented to the wife how nice the beam was and very comparable to the SC430 OEM HID's.
Thats what I got, the 5K unit. I read one of your earlier post and you said you posted some pic, so far no luck finding them.
Sorry , don't post much here anymore, did not seem to be much interest in mods.
Here are my lighting mods:
5k HID McCulloch headlights
Piaa Extreme White fog lights
LED side step lights
Here is a pic of the headlights. GX is at an angle, not the greatest pic. No old vs new shot here.
Piaa Extreme White foglight on the right (as seen in pic) vs stock on the left
LED side step bulbs (right)-huge difference over yellowish OEM (left). Makes the GX look modern
Headlight install pics
Lol, we must think alike, I have the Piaa Extreme White fog lights too. I originally had the PIAA LED in the running board as well, but they were not bright enough, so I put the LED in the parking lights and put some MTEC tinted bulbs on the running board.
One more question if you don’t mind. I don’t see the igniter in the passenger side picture, where do you install it. Also, did you double sided taped everything or did you bolt them down?
Thanks
Thanks
Not sure about the igniter, would have to check as it has been a while since I looked under there. Everything is bolted. I believe the pic above shows some components with tape but everything was changed shortly afterwards to hard mounts for added security. Would have to take new pics.
In my experience, XenonDepot HID kit is far more reliable than Sylvania Silver Stars. I have had XenonDepot HID on my GX since 2004 with no problems so far. I replaced the Sylvania Silver Stars on my RX almost every 6 months.
To be honest, I don't recall. I believe is reused existing holes and possibly shifted things around.
On the Silverstars, the older versions had issues with premature burn out but the new Ultras are pretty decent with very little return rate.
Pearlpower,
Do you have any issues with flickering or "strobing" of your HIDs? My understanding was that you needed a separate power source from your existing harness in order to prevent that from happening. I'm leasing my GX and running additional wires, relays, etc. - would require me to remember to remove it later when I return my GX (well, unless I keep it). Plug-n-pray would work great for me.
Let me know, Thanks.
Lights are install, they look great. Thanks for the advice pearlpower.
gsobol, on some cars, the HID light have to be draw power directly to the battery. GX is not one of them, since the lighting circuit is pretty heavy duty. If you dont get enough power to the HID, they will flicker.
After driving around with the Mcculloch 5000K kit for 3 weeks, I am not happy at all with the light output, especially in the rain. I broke down and bought a set of Philips 4300K bulb, I am now running Philips bulbs with Mcculloch ballast The difference between the 2 bulbs are like night and day. I would say at least twice as bright. I know they are difference color temp, but even if the Mcculloch was 4300K and didnt have that tint on the bulb, I think the Phliips bulb is still much brighter. I am now one happy camper, another expensive lesson learned.
Pearlpower,
So the debate is still in the air. I should be receiving my XenonDepotKit in the next few days and this time I will use a relay because it is included.
My 2 cents.
Pearlpower,
