How to change the oil on your GX470
Old 09-21-15 | 07:24 AM
  #46
techrep's Avatar
techrep
Originally Posted by Aristanet
or you can just go to Jiffey Lube and for $25 get an oil change and free carwash
I would not let Jiffy lube change the oil in my lawn mower...
Old 09-21-15 | 07:25 AM
  #47
techrep's Avatar
techrep
Originally Posted by SC3coupe
Does the skid plate has to be removed completely like this one to change the oil filter?
Yes...It does
Old 09-21-15 | 08:32 AM
  #48
IanB2's Avatar
IanB2
Yes, but that's just the forward-most skid plate, the rearward one is separate and does not need to be moved.
Old 12-13-15 | 07:32 AM
  #49
SC3coupe's Avatar
SC3coupe
I just completed the GX oil change the first time of my new ownership, this post is very helpful but I would highly recommend removing the rear skid plate, it is only 4 bolts..
The reason is when I dropped the plug the oil hit my hand and splattered and then it came leaking out of the skid plate in random places. (there is not a lot of room for hand, bucket and tool). I do not want to have oil drip out after I am done. I took out the rear skid plate off and here is a picture, doesn't look like I was the only person who had been spilling on it. I had to clean this and the cross member of the mess. It may be just me but seems like the oil comes out really fiercely and get all over the place.
I bought the filter socket from amazon and it works super easy with a ratchet
Also, overtime the mechanics that worked on the car used impact because they were way over tightened for a M8x1.25 bolt, one of them was cross threaded and needed to be chased with a repair tap. OK for now but need to be helicoiled in the future, I always hear about these bolts being stripped.
I am missing the cover for the access hole, I have heard people complain the dealer never put it back.
Old 12-13-15 | 11:22 AM
  #50
Rockbus's Avatar
Rockbus
Agree 110%. These jokers want to churn and burn cars through their shop as fast as possible. Most of them at just kids that don't know doo doo. I've got a built up XJ that I took to a jiffy lube just once. I've replaced the whole drive train*. These jokers told me they could not find the correct oil filter (it was a big deal for them for some reason), then they tell me they topped off the fluids on my tcase, diffs, windshield washer etc.
So I quiz then on how they checked the oil levels on my crawler box and altas, and to show me. Obviously, they had not idea. I bet they never saw a crawler box before.
Stay away from these nuts unless you watch them like a hawk.
Ray
* The XJ has a 318/518/KluneV/Atlas....
PS Don't even ask me about Encinitas Foreign car repair and ripoff.
Old 12-13-15 | 11:59 AM
  #51
ALAN553's Avatar
ALAN553
http://www.fumotousa.com
Makes oil change a snap, attach hose to valve and drain wherever you want. That plastic cover...pretty delicate, plastic hooks break off pretty easily
Old 12-17-15 | 03:01 PM
  #52
DonnyBoy's Avatar
DonnyBoy
Originally Posted by AustinGX
This really make life easier when changing oil,
it's also very useful for visual inspections.
Attachment 108246
How much do those cost? Would love to have one.
Old 12-18-15 | 04:51 AM
  #53
burny's Avatar
burny
cheap bro go to Amazon and get you some
Old 12-23-15 | 09:22 AM
  #54
techrep's Avatar
techrep
$26 and change plus shipping Amazon ...you need the F103 M12X1.25
Old 02-14-16 | 09:28 AM
  #55
djspock303's Avatar
djspock303
Admins - Sticky DIY Possibly?
When you are desperate and you have a oil filter that was on to tight, or just doesn't want to come off, or you don't have a fancy oil filter clamp/wrench then result to the old racer/mechanic knowledge.
Get you a hammer and a screw driver and a trash bag. You can hammer the screw driver into the oil filter near the top of the filter (not the part by the engine block) and use that screw driver to get you leverage on the filter to "unscrew it" or at least loosen it until you can do it by hand. Your going to dispose of that filter anyway. Just my two cents. -
Old 02-14-16 | 01:23 PM
  #56
burny's Avatar
burny
You would have to be desperate
Old 05-01-16 | 03:08 PM
  #57
xpeng's Avatar
xpeng
Does it need a drain plug crush washer? Metal or plastic?
What's drain plug torque? 30 lb-ft?
Thanks.
Old 05-01-16 | 04:07 PM
  #58
co4wheel's Avatar
co4wheel
I can't remember for sure, But isn't ours on the back of the pan, kinda pointing at an angle. Wouldn't that thing hang a lot lower and be at risk of snapping off if you hit it on a rock or something? I always worry about those things.
Old 05-01-16 | 04:54 PM
  #59
ALAN553's Avatar
ALAN553
Drain valve at least 4-6 inches above skid plate....
Old 05-01-16 | 06:31 PM
  #60
co4wheel's Avatar
co4wheel
Probably safe then
