I did it! 24's ONLY ONE in MIAMI
well, I went to reds
MAJOR PROBLEMS ABOUT LOWERING
If I really want to slam it and make it sit on top of the tire, (dont make fun of me how i explain it im not a car pro so i dont kno the names of every part, bare with me) i have to turn my AWD truck in to a 4x2 because for me to go that low he said i would blow a front axle which rotates the tire because i would be at a angle to much, anddddddddddd I have to cut my stock springs, which really blows. He kept telling me go air bag suspension that it would ride better, but i dont know i dont like that whole idea, come on doing that to a 1972 impala caprice,mayb yes not to a 2007 50k dollar truck, but that gappppp, is destroying me. I was thinking leave it like that, and do something crazy with the system
i removed my 3erd row, so 4 15's sound pretty good to me.
so i should screw the lowering right?
hello, may i suggest that if you are going to install 4-15s, possibly extra battery, amps etc and knowing that mdf ( which is normally used for building boxes) weighs in @ 108-110 lbs per 4x8 3/4 inch sheet. not to mention the weight of the speakers and any internal bracing, that you wait to lower your vehicle. I have had customers in the past that did not want to wait till after their appointment to have a large audio install and go ahead and have the car lowered only to have it towed back to the lowering shop to have it lifted back up a bit. turns out to be some sxtra wasted money. just thought i would throw this out there.
i've pretty much given up on it. oh well.
....waiting for the new LX to make it's arrival.
Well, allison lowering the rear they told me would be simple and NO PROBLEM, problem is up front, ima go today, i might switch to 26's screw it, leave it at normal hieght and do a radical system
poorawls
SC- 1st Gen (1992-2000)
21
07-19-10 07:00 AM
