Xentech HID'S Flickering on Highway.
Now I know this has been talked about but I cannot find anything directly stating how to fix this.
My problem is ONLY on the highway one of my lights flicker randomly goes on and off and its highly annoying I have double checked everything its all nice and tight even tried pulling the wires and it wont flicker I have contacted the seller he stated that the kit is designed to work without a relay or external ground.
My question is has anyone had the issue where it flickers at high speeds only not when starting i have no problems there I even have my lights set to auto. Here is a link to the type they are http://honda-tech.com/zerothread?id=2053835&page=1 if anyone has any clues please speak up.
If this is in the wrong section feel free to move.
I have switched the bulbs and the ballast's around and mix matched and its the right side. I have been in contact with the seller andyes it is under warranty they are willing to swap whatever piece I need in advance for me so I am not without.
They actually just called me about a hr ago and told me a couple things to look for mainly the mounting location of the ballast where I had it mounted if I put alot of pressure on it it would hit the body of the car so I moved the mounting location and once it gets dark I will jump on the highway and see..
Hopefully that was it if it was I will be ordering another set for my fogs HID's are a must...
Drzava
11-10-11 02:51 AM
